|  | Home > Maintenance & Modifications > Receiver hitch question |
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327      | Tough call that one, but even so, if it doesn't have to be approved, your insurance co. may think different? Craig Rogers
 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography | ||
|  15th Dec 2013 4:22pm |
| leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584    |
 I believe that is classified as a commercial vehicle and hence does not legally have to use type approved towbar. Now can/will an insurance company require you to have fitted something that the law does not require? That is not a question I can answer. That is between you and your particular insurance company. Brendan | ||
|  15th Dec 2013 6:17pm |
| landys1 Member Since: 04 Dec 2013 Location: Cheshire Posts: 134      | Ok, thanks, better check with the insurance company then to be on the safe side 1959 Series 2 Ragtop
 1989 SWB Stationwagon 1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work) 2011 Puma 90 2.4 XS | ||
|  15th Dec 2013 7:26pm |
| Pam W Member Since: 25 Oct 2011 Location: North Yorkshire Posts: 1169      | My 1998 Defender is classed as a commercial van because it came out of the factory as a hard top (no windows and no seats in the back, ie. not a Station Wagon). It has had windows put in later and at one time also had seats in the back, but it still retains its 'hard top' identity.
 As it is pre-2000 I pay the same VED as a same age SW though, so it is really only on newer post-2000 vehicles that checking what amount of VED you pay tells you what class it is. My 90 is also classed by the insurance people as a commercial van. The insurance company has access to a database which decodes chassis numbers and tells them if a vehicle is a commercial or not. I used to have mine insured as a private car until the insurance companies got this database. Now it has to be a commercial and I have to stump up about £100 more per year to insure it as a consequence!  However, it does mean I can legally use a receiver hitch   On older models like mine it doesn't tell you much on the V5C, and of course the body type may have been changed before your ownership, but the VIN number code can confirm the original classification. FirstFour have conveniently provided a decoding page to help you work out what your own vehicle is. http://www.firstfour.co.uk/products/land-r...nformation Our blog - http://landytravels.com/ Yorkshire Off Road Club - http://www.yorkshireoffroadclub.net | ||
|  15th Dec 2013 10:11pm |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491      |
 correct its commercial, you dont need type approval towing. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop | ||
|  16th Dec 2013 4:10pm |
| landys1 Member Since: 04 Dec 2013 Location: Cheshire Posts: 134      | Great, thanks for that   Makes towbar choices a lot easier... 1959 Series 2 Ragtop 1989 SWB Stationwagon 1998 300Tdi Hard Top and 2012 2.2 Puma Hardtop (at work) 2011 Puma 90 2.4 XS | ||
|  16th Dec 2013 4:18pm |
| Mr Fox Member Since: 10 Sep 2011 Location: green & pleasant land Posts: 1047      |
 This looks ideal. I cannot see this part on the web site mentioned; does anyone know of another source for it? I assume it isn't simply the plate but also the support underneath? | ||
|  16th Jul 2015 7:37pm |
| DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 271      | AM94,
 Contact Leeds, Brendan at 4x4 Overlander , and I'm pretty sure he will be able to supply, as I bought mine from him. Kit includes plate and support, plus ties to chassis. Other parts such as recovery pintle and drop tow hitch were extra. Worthwhile modification for my use. Good luck | ||
|  16th Jul 2015 9:14pm |
| Mr Fox Member Since: 10 Sep 2011 Location: green & pleasant land Posts: 1047      | Thanks DC101 - will do | ||
|  17th Jul 2015 8:24am |
| nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546    | Together with a Type approved Towball this is a perfekt combination:
 http://nakatanenga-tours.de/shop/article_A...KMM-030%26 WANTED: SII or SIII in max 1.5k | ||
|  17th Jul 2015 8:33am |
| Brewstop Member Since: 28 Oct 2012 Location: South Oxfordshire Posts: 315      |
 Is this the type approved one? Sandy | ||
|  17th Jul 2015 6:07pm |
| Posting Rules
