Home > Td5 > TD5 disco for parts
darryloh
United Kingdom 2000 Defender 90 Td5 HT Coniston Green
TD5 disco for parts
Hey, I've been offered a rotten td5 disco, and wondered what parts would be useful for my defender td5, they are both year 2000. Any thoughts?
Post #290698 15th Dec 2013 11:47pm
Not a huge deal.
Engine (the basic lump is the same. but the defender has different wiring loom on it), exhaust downpipe.
transfer box (if it's got the difflock linkage on it)
seats maybe, if you fancy grafting them into a defender.
Some people fit the drop arm off of the disco steering box, onto a defender, as it has a normal balljoint/TRE not the circlip/spring affair that the defender had.
engine ECU & 10AS alarm unit.
A friend of mine in Reading breaks discos, and he usually manages to sell all the interior in ebay, and (if the bodywork is straight) most of that too.
axles too, if they're straight, will fetch some money. Diffs are different to defenders (apart from the new type 110/130 rears), the disco /may/ have a 4 pinion in the rear.
Post #290742 16th Dec 2013 8:45am
Are your sure? I though that the Disco2 had Rover pattern diffs (not P38), and that (subject to a flange swap) a Disco 2 diff would fit either end of a 90 or the front only on a 110/130. As far as I know they are 24-spline, two-pinion units (I've never met a 4-pinion Disco2 diff but that doesn't mean there aren't any).
See also this thread - dilukabey has fitted a Disco2 rear in place of a broken Puma 110 front diff.
Post #290766 16th Dec 2013 11:07am
ah OK, must be P38's i'm thinking of Embarassed
Post #290775 16th Dec 2013 11:20am
