Home > Puma (Tdci) > Had to tow a 90 with a rope for 70 miles ;-(
Ian Mac
2008 Defender 110 Puma 2.4 XS CSW Java Black
Evening
I had to tow a fellow Landy 70 miles through lanes and villages today with a rope.. Pull away in first then changing to second third and so on the rope goes slack and a huge jolt as the ropes slack is taken up...
I know we should not tow with a rope no more but it was last resort for a fellow Landy owner.
Now my question is .... When changing up and this slack was taken up the jolt caused the traction control light to come on and a chain like slipping noise was heard??? Also should I check any components after this unforscene trip???
Ian 2008 TDCI 110 XS
1985 90 300tdi. Gone
2005 RR vogue TD6. Gone
Post #290641 15th Dec 2013 9:21pm
Romadog
Towbar bolts...
The jolting is mostly down to the driver that is being towed. They should aim to keep the rope taught by using their brakes. The only way to stop it would be to use a rigid bar, but that brings in other issues.
Get a deal with a national breakdown company.
Post #290652 15th Dec 2013 9:38pm
Happyoldgit
The noise is just the traction control doing it's thing. Smoothness is key when towing and as been said it sounds like the driver being towed did not use their brakes to keep the tow rope taut. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #290662 15th Dec 2013 9:51pm
Ian Mac
Yeah was a very rough 70 miles! Sounded like the rear end was going to come off and gear box fall out at times. Kangaroo style of driving Sad
How would this of been on gear box clutch and drive train??
Post #290666 15th Dec 2013 9:58pm
walfy
This where a kinetic rope is useful. As long as you understand the forces involved. I'd rather be towed with a kinetic over a normal strop. But 70 mile is pushing it a bit. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #290670 15th Dec 2013 10:08pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
If you were triggering the traction control, there must have been a hell of a strain on the towing/towed vehicles. Was it particularly slippy...?
I can't imagine you've done much damage to the drive train (unless the clutch was slipped or dumped), but I'd check the towing points on both vehicles, they sound like they have taken a large shock load.
Simon
Post #290678 15th Dec 2013 10:14pm
DRW58
Scotland 2001 Defender 90 Td5 SW Epsom Green
Talking of tow ropes/ strops
I'd like to buy one but not sure what to get or where, I'd really only need one to pull others back onto firmer ground / road when they get stuck.
Have heard horror stories about kinetic ropes, and am certainly not going to go out looking for trouble, just think it would be a useful addition to my jump leads, spare jack, torch, spade, etc.
Thanks in anticipation
DRW I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and Censored all's where it should be!!!! Ho hum
Post #290683 15th Dec 2013 10:19pm
Ian Mac
We used a 10ton pro comp recovery strop doubled up so no give in it what so ever. Clutch was not dumped but as changing up the vehicle behind got closer making the strop get slack Untill drive was taken up again. It was hell of a day but it had to be got home
Post #290686 15th Dec 2013 10:24pm
Ian Mac
And yes hell of a strain. As the towing vehicle changed up the strop got slack and when drive taken up it jolted the vehicle a few times Untill it once again become steady tow. This causing the towing vehicle to get pulled back and traction control kicking in. Not a experience I would like again
Post #290689 15th Dec 2013 10:27pm
leeds
70 miles? Best on a trailer or a flat bed.!
In a nut shell the stiffer the towing equipment then when slack occurs the higher the peak force.
This comes out of the laws of physics.
Basically
Force = Mass x Acceleration M = fa
In our case it is deacceleration rather then acceleration which is just mathematically a minus or plus sign.
Deceleration is controlled by the stiffness of the towing medium. The higher the stiffness the higher the peak force.
So assuming same length of the towing medium, the same amount of slack then in order of stiffness or peak force
1) metal chain highest
2) polyester tow strap/lifting strap medium
3) nylon kinetiic strap or rope lowest peak force as it has the highest elongation.
It depends on the skill of the driver being towed. If they keep the towing medium taut then little peak loads. If they allow slack to build up then steel chains will give you massive peak loads, polyester straps medium, nylon straps lower peak loads.
Moral of the story? Do not allow slack to build up!
Brendan
Post #290704 15th Dec 2013 10:59pm
Cuthbert
I read this thread and kept thinking "Ouch"! .......... "Ouch"! .......... "Ouch"! .......... "Ouch"! .......... for 70 painful miles.
Post #290714 15th Dec 2013 11:32pm
Ian Mac
Unfortunately a trailer or flatbed was unavailable.
And yes ouch for me towing on every gear change, I think I have whiplash now Sad ha ha ha
So Should I worry about my car or would this trip have been fine on it and just a learning pointer??
Post #290754 16th Dec 2013 8:32am
It is for precisely this reason that i will never tow someone who doesn't know how to be towed!
Post #290756 16th Dec 2013 9:00am
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Its easier if the tow vehicle is an auto Thumbs Up 2005 Td5 90 XS
Steve
Post #290757 16th Dec 2013 9:12am
Ian Mac
Now what would would of soaked up them stresses then?? Would they of been absorbed by the car or transferred to the clutch or straight to the engine and crank???
Post #290970 16th Dec 2013 11:03pm
