![]() | Home > In Car Electronics > CB Radio wiring advice |
Ah cheers, didn't notice that!
What's better in your opinion out of these two? http://www.autoelectricsupplies.co.uk/product/303/category/62 http://www.amazon.co.uk/standard-Splash-pr...B004JFRWO4 Cheers ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21015 ![]() ![]() |
Amazon one bud.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Gum,
Not sure what extras you may have fitted already or what your plans are but it could be time to fit one of these perhaps? Makes future additions so much easier. ![]() http://www.seamarknunn.com/acatalog/blue-s...tAodPjcAIg Some pictures have been cleared out but the fitting details are contained herein.... http://www.defender2.net/forum/topic20439-15.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 15th Dec 2013 7:55pm. Edited 1 time in total |
Mal, he mentioned on the previous page there isn't enough room in the battery box as I suggested a similar solution.
Could be located elsewhere but not worth the hassle really I guess. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Missed that about the twin setup, nevertheless a Blue Sea would fit under the driver's seat. It's not that big. On a Puma it would also fit in the same panel where your fuses and relays are kept under the dash but on the passenger side, there's bags of room in there. Not sure on Gum's model though? If you go through life with your head in the sand....all people will see is an ar5e!!
I'm on a Tdi Mal, and I've got a fuel tank under my drivers seat
![]() Ring terminals ok for connecting to battery terminal? Or is there a better solution? Pete An engine to TDi for! "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Some of which like the winch was used last when?
![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
![]() ![]() ![]() "Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
Ring tongues are fine or if you've a mega fuse fitted a ring tongue connected to that is even better.
![]() Treat every day as if it is your last....one day you will be right!! |
Excellent! Thank you all for the advice
