![]() | Home > Puma (Tdci) > The distant sound of a small dog "yelping"..Really |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233 ![]() ![]() ![]() |
Mine has just started doing the exact same.
My clutch has been on the way out for far too long with the clutch rattle starting about 7000miles ago. About to change the clutch, but yesterday the 'yelping' started when I turned the engine off. It seemed to replace the 'chukka' noise. The engine light came on yesterday having done 250 miles into a 600mile journey. Sudden loss of power so pulled over. Restarted and the power was back, but the light remained on. Checked codes and no faults showing up. As the journey progressed the yelping would start when taking foot off accelerator at about 20mph. It is steadily getting more frequent with still no codes coming up. |
Landyphil Member Since: 23 Jul 2012 Location: Lake District Posts: 87 ![]() ![]() ![]() |
^ Yup that is EXACTLY the symptoms although I've yet to get a limp mode or loss of power....but wife needs to use it tomorrow so will have the toughbook plugged in today.
I'm beginning to doubt myself and wonder if it is EGR based. Will see if the there are any spikes or sticking points if I set it record the EGR feedback while driving. Under warranty the other year we had the MIL light on and it was the unsurprising "too much clean air entering my manifolds rather than eating my own crap that I should be using for no good reason" fault code. A graph of the EGR feedback showed it kept jamming. Will hopefully find out. 90XS Tdci John Eales 110 CSW G4 Edition 88" Series 3 Racer |
Got it!
It's the EGR. It seems that the rate of commanded EGR varies with revs so driving on normal road speeds it opens and shuts the EGR quite quickly BUT letting off throttle at lower revs or gear changes (same thing I guess) it seems to instantly want a lot of EGR! That spike of demanded EGR coincides with the "yelp" every single time. I'd guess the crappy nylon gears coated with soot are shuffling off their mortal coil having completed their life of evil. Oddly though even the cleaning cycle when you knock the engine off sounds normal but it doesn't seem such a steep curve as gear changes? Either way I can either change the EGR (spend money on something that shouldn't be fitted in the first place) OR....(and I'll have a search now) find if anyone can leave my map standard (quite happy with it) but deactivate the EGR so it just remains shut but doesn't flag up the "too much clean air passing through the MAF" warning light and code. 90XS Tdci John Eales 110 CSW G4 Edition 88" Series 3 Racer |
I now have an EGR closed map but historically it was a different one. Here's a potential solution from a four year old thread....
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I did wonder about cleaning but it's putting off the inevitable. It's a poor piece of kit that has no place in my engine bay and the last one only made 40K before it was nailed. 90XS Tdci John Eales
