Home > Puma (Tdci) > Main battery charge on IBS split charge system
Blacktt600
England 2008 Defender 110 Puma 2.4 XS CSW Cairns Blue
Morning all. i picked up my new vehicle on Friday pm and this morning it failed to start. It has an IBS split charge system installed with 2 optima batteries fitted. My question is can i just charge the red top with it still connected to the vehicle or is there anything i need to be aware of with the IBS system? im hoping the battery is just low owing to it been stood for several weeks in the workshop. I did manage to start it by linking the 2 batteries using the IBS panel on the dash.
Post #290457 15th Dec 2013 1:20pm
leeds
Yes you can connect the ctek charger direct to the main battery. As the main battery voltage rises the relay will kick in and you will land up charging both batteries. It might take some time to charge both batteries this way dependent on what ctek charger you have. If you want you can disconnect the second battery from the relay if you can get to it.
If the Optima has been stood quite a while discharged it might not be in the best condition. Might be worth while measuring the battery voltage prior to charging with a decent multimeter, measure it after charging and then 24 hours later.
Brendan
Post #290467 15th Dec 2013 1:55pm
Blacktt600
Thanks for that, I only have a very basic charger (halfords type) hopefully shouldn't be any problems using this. Once I get my head around what sockets and lights are running off which battery I may be asking some more dumb questions!
Post #290475 15th Dec 2013 2:43pm
Blacktt600
I also have an isolator (red plastic key) on the seat box which I have just noticed. Any idea what this would be used for? It doesn't seem to turn anything off. Obviously I realise you can't say for sure but any pointers?
Post #290490 15th Dec 2013 3:54pm
GUM97
Has your vehicle ever had a winch (or similar) fitted? An engine to TDi for!
Post #290494 15th Dec 2013 4:03pm
Blacktt600
Yes it has a winch fitted, not that I need it though. It was already on when I bought it. Maybe the isolator for that then?
Post #290496 15th Dec 2013 4:05pm
GUM97
Yep, that's probably it! Most winch wiring systems include an isolator switch like that one, to stop it from drawing power when not needed and then flattening the battery Thumbs Up An engine to TDi for!
Post #290498 15th Dec 2013 4:11pm
Blacktt600
So if the switch is in the on position that could be the cause of the flat main battery.
Post #290499 15th Dec 2013 4:13pm
GUM97
Yep that's very likely! Make sure the isolator switch is in the "off" position and see how it goes. Fingers crossed that's the problem, as its a very simple one to rectify! An engine to TDi for!
Post #290501 15th Dec 2013 4:23pm
Blacktt600
Well it can't be that that's flattening the battery. The key only comes out when it's in the off position. Will leave it on charge and see what happens tomorrow morning.
Post #290521 15th Dec 2013 5:15pm
leeds
The winch is unlikely to be a significant drain on the battery if power is just switched on to it. The solenoids/relays will not be energised until the wander lead/remote is triggered then it will be a significant drain on the battery.
Having said that if it is a bridge type winch with a built in light then that would be a current drain. These lights are not very noticeable.
The alarm, the analogue clock will have a continuous current draw on the battery and are the most likely cause of the battery drain, alongside any interior light being left on.
A recommended battery charger would be a cTek charger and there is a group buy going on in the sister site www.disco3.co.uk
Brendan
Post #290535 15th Dec 2013 6:08pm
Blacktt600
Well it's been in charge for 6 hours and voltage is 12.8, it was 12.2 at the start of charging. The winch is a warn 9.5ti and the isolator key is out so assume its in the off position. I'll see what it does in the morning and put it back on charge for a few more hours tomorrow. Fingers crossed!
Post #290627 15th Dec 2013 9:54pm
leeds
Warn 9.5 Ti
Remote Control: Remote switch, 12' (3.7m) lead, thermometric indicator, S2 elements, integrated flashlight
It has a integrated flashlight.
So clock + alarm + flashlight on + few weeks = flat battery.
Am not really surprised.
Optima red top at 12.2 volts not capable of starting engine?
A fully charged battery should be at about 12.8 volts
Now an Odyssey 1500 sat at 12.2 volts should be capable of starting a Defender engine as it is only at about 50% discharge.
Now why should not an Optima at 12.2 volts not start an engine.
Several possible explanations.
1) Incorrect voltage reading on open circuit
2) Battery not in best condition
3) Bad battery/starter connection limiting current flow
4) Starter motor problems
5) Errr, pass
Now if the Optima does not respond, I would suggest an Odyssey PC1500 which IMO is a better battery as a replacement.
Brendan
Post #290647 15th Dec 2013 10:30pm
Blacktt600
Can you expand on the integrated light? The lead isn't connected so surely not a problem. If the optima doesn't respond I'll be making a Phonecall tomorrow to where i got it from, only picks it up on Friday night. It started fine when I linked the yellow and red together using the control panel.
Post #290653 15th Dec 2013 10:39pm
leeds
The integrated light is in the bridge of the winch. It is to enable to watch the wire being spooled onto the drum. It is a low light output/current draw
It normally comes on when the winch is powered up. The wander lead/remote controls the power to the solenoids which controls the main winch drive in or out.
Note that the Optima red top is a starter battery whereas the yellow top is a combined starter/leisure battery. From personal experience I rate the Odyssey batteries over the Optima batteries.
Brendan
Post #290707 16th Dec 2013 12:09am
