![]() | Home > Puma (Tdci) > Max engine revs - hill descent - how high is too high? |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1596 ![]() ![]() ![]() |
Would not want to do it everyday but it will be fine. Land Rover test their engines off road and they push them pretty hard. Your engine won't blow up and will blow the cobwebs out.
Don't break going down hill off road. Best thing todo is remove foot away from brake pedal to stop temptation of trying to brake There's a video on you tube were a 90 applies the brakes on a steep decent and he tips over.
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 ![]() ![]() ![]() |
Hello,
I can,t answer but on the same subject I have the feelingthat the engine brake is less powerfull as with older land rover. Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
Just make sure your engine is at temperature before doing the rough stuff.
And have it run iddle or drive carefully after for a minute or two, so your turbo gets cooled bedore turning the engine off. In fact, do that always, also after a long drive. |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2684 ![]() ![]() ![]() |
@op On those very log, very steep descents, I feather the brakes very lightly every now and then just to keep the revs down a bit.
It is interesting to note that under compression, the engine is actually not burning any fuel. In fact, after these long descents, the EGT on my Puma has down to as low as 60C! And yes, let the vehicle idle for a few minutes always! ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2791 ![]() ![]() |
Yes the engine braking isn't great on the puma, I guess the compression is just too big/small (can't remember which haha!) I've found some light braking just to keep the revs down can help, but it usally would cope on it's own- I just chicken out
I got taken around a purpose built quarry at LRE peckforton castle in a 2.2 110 and the driver never once touched the brake, and we were going down slopes so steep that the tow bar bottomed out leaving it.. Coped fine Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
Engine braking is quite good on a Puma 2.4. That engine's compression is 17.5 : 1
Thę Puma 2.2 has a lower compression rate of 15.5 : 1 I have tested a friend's new Puma 2.2, and there definitely is less engine braking than on my Puma 2.4 If you do a search, this discussion has come up in various threads already, not everybody agrees with what I say here, but I have experienced the difference. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 ![]() ![]() ![]() |
Agree with engine braking on the 2.4, very good.
I suspect even the 2.2 is still better than the Jap stuff. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
