Home > Technical > Air suspension on a 90
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
Hello,
I thought that i would put it on here, i have just ordered my vlair system and p38 air bags in the start process of making my 90 ride on air. i wondered if there is anyone out there that has any info regarding the air input into the bags, i was told by p38 spares that it is just a 6mm dia tube, but i dont know whether this is direct into the bag or there is other valves etc that are in the top of the bag? Does anyone know? Also if there is anyone out there wanting to do it, i would be glad to work with you on this project. I am goiong to try and keep all the details and photos logged down, as it would make an interesting conversion.
Post #289787 12th Dec 2013 3:01pm
munch90
fitting air bags, compressor, pipe work and valves is not a big problem .. its the level sensors electronic side in more the problem .. or if it can be done manually with pressure regulators
mate had a classic range rover with air suspension fitted maybe 15-20 years ago that seem to work ok ..but worth all the work not sure
Post #289799 12th Dec 2013 4:09pm
Will.I.AM
i am going to use festo maual regulators as this is an easy option and we have all the parts on the shelf!!
worth the hassel.......i'd say so, it makes it different as well as functional and comfortable.
Post #289801 12th Dec 2013 4:12pm
jst
Si Rafferty (X-Eng) ran a 90 on full air suspension not so long a go, try pming him on here. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #289882 12th Dec 2013 7:03pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
On my old Disco 2 the pipes were a push fit into a a union on top of the airbag. I replaced the pipes from the compressor to the bags but don't recall there being any other valves.
I'm guessing the P38 bags are fairly similar. Be careful when routing the pipes, being plastic they tend to rub through if fouling any bodywork or the chassis due to vibration. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #289897 12th Dec 2013 7:24pm
theorangebandit
I have considerwd air ride, but it seems yo work in the opposite to the desired affect. For instance on road the ride needs to be smooth yet firm, and off road needs to be soft but raised.
To gain the height off road means stiffening the ride.
To drop the height on road means softning it.
Im open to suggestiin on this as I still really like the idea of fitting air ride.
Can I ask are you using a bag and shock setup or a bag and spring?
Post #289921 12th Dec 2013 8:32pm
ibexman
Each bag needs to be a different pressure for the vehicle to sit level Whistle
Post #289948 12th Dec 2013 10:00pm
Will.I.AM
i have order new p38a air bags and i am going to use all festo valving gear and guages and have a manual set up for adjustment under my cubby box or in front of it. I was going to run the rears and the fronts as two pairs, but it can be dodgy, even with a compnsating valve in the middle. The lower you go the softer.....this is ideal coz you get a nice ride and it gives you the pimp look. I have ordered a vlair compressor from america, heavy duty system as this can be used for tyres and tools as well. I will have this all mounted inside with my 240v inveter as well.
I guess most people hate pimping up defenders, but i have had two years of off road mud and wading, now the time has come for performance and pimp?!......... Laughing Thumbs Up
Post #291112 17th Dec 2013 4:01pm
rvdb
Can you share any updates about your project with us?! Thanks!
Post #321503 4th Apr 2014 11:07am
Will.I.AM
It is nearly complete now, i have put all the air bags on and they are running fine just on Shreader valves so i have to manually adjust the spings. The ride is excellent, it is like a medium duty set of springs, but the harder you ride them, the softer they feel. What i mean is, (for those of you who have a disco 3 or new rangey you will know what i mean) if you hit a speed hump at 20 you feel it a lot!! but if you hit it at 50/60 mph, it just gets 'absorbed' Whistle
Will put some photos in my gallery as soon as poss
Post #321534 4th Apr 2014 2:03pm
rvdb
Haha... Sounds good not stopping for speed bumps.
Looking forward to the pics. And also a installation guide and a list of used materials??
Post #321535 4th Apr 2014 2:05pm
william8
Scotland 2008 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Any updates on this Will.i.am?
Im William and am at university just now doing electrical and mechanical engineering. Thinking about doing this to my motor but i would be more interested in the electrical side of things. I would be looking to run a micro controller and electrical valves to increase and decrease the pressure was you go so that it sits level automatically with weight and with cornering. How far did you get with your automation? William
Post #332297 20th May 2014 2:45pm
H3nry
Will,
Any update on the air suspension?
Post #351694 14th Aug 2014 11:03pm
ibexman
Are the P38 bags a straight swap for the springs
Post #351764 15th Aug 2014 1:19pm
jomara
Scotland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Not sure if you guys have come across this, found it in my old bookmarks
http://www.x-eng.co.uk/sproklegrommet/lrsuspension/index.asp
Interesting write up on an airbag installation.
John 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto
2022 110 D250 XS Edition - Gone
2024 110 D250 X-Dynamic HSE
Post #353914 27th Aug 2014 6:44am
