Home > My Defender > Black 90XS now with sawtooths and AT2`s
forest172
2013 Defender 90 Puma 2.2 SW Santorini Black
Before and after shots proper pleased with how it`s made it look
Post #289765 12th Dec 2013 1:43pm
willyj
United Kingdom 2011 Defender 110 Puma 2.4 USW Stornoway Grey
(Dribble smiley face)
That looks sweet! Thumbs Up
Post #289766 12th Dec 2013 1:45pm
Very nice Thumbs Up
Post #289767 12th Dec 2013 1:47pm
pjb
offset on sawtooths is better than the boost so looks a little wider Thumbs Up 2020 P300 HSE
Post #289771 12th Dec 2013 1:57pm
forest172
then with 265/75 instead of the 235`s looks better too
cheers all
Post #289772 12th Dec 2013 2:00pm
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
That looks good... fills the arches nicely without getting too " Red Neck " looking.
As a mater of interest what is the off set on the sawtooths ?
N.
Post #289774 12th Dec 2013 2:05pm
Looks good, can't be ZU's and the sawtooths. Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #289775 12th Dec 2013 2:07pm
9t
South Africa 2013 Defender 90 Puma 2.2 CSW Fuji White
Looks superb, well done mate. '13 Defender 90
'10 Freelander
'13 BMW R1200GS
'62 Triang Tricycle
Previously '04 R1150RT; '11 F650GS; '98 Defender 110; '03 Defender 90; '02 Freelander
Post #289810 12th Dec 2013 4:38pm
ChrisD90
United Kingdom 2013 Defender 90 Puma 2.2 HT Corris Grey
Very tasty all in black Thumbs Up 2013 Defender 90 HT
Range Rover Evoque
Post #289811 12th Dec 2013 4:40pm
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
ET 20, I think, compared to the 33 standard. So it stands 13cm wider on each side.
A 265 tyre compared to a 235, adds 3cm in total or 15cm on a side, so you get about the same effect.
If now you fitted 265 tyres, you'd have a stance like a 285 tyre on standard rims, in fact it'll be 8mm wider on each side and probably stick out of your arches.
In fact 255 would be better but then you 'd have a higher tyre, as they are 85s too, which is not good either.
I'd stick to 235s on those rims if I were you.
Post #289832 12th Dec 2013 5:06pm
zone30
How it works:
ET = distance center of rim to where it's bolted on, less gives more left to stick out.
235x85x16=>
16 = rim diameter in inches
235 = tyre width in mm
85 = tyre rubber height in percentage of width (235 x 85%)
Full diameter = 2x rubber height + rim diameter.
The rest is just Maths and logic.
Post #289839 12th Dec 2013 5:13pm
forest172
Post #289877 12th Dec 2013 6:57pm
GUM97
Smart indeed! Mr. Green An engine to TDi for!
Post #289911 12th Dec 2013 8:11pm
Cakey
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Like that
Post #289917 12th Dec 2013 8:21pm
sweepc
2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Love it Thumbs Up
Post #289932 12th Dec 2013 9:01pm
