![]() | Home > Maintenance & Modifications > MOBILE STORAGE SYSTEMS - NEW "HIGHLINE "STORAGE SH |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
Darren, Do you have any pictures of how you built yours..? Cheers Simon |
Hi Simon,
Strangely for me, no. Probably because I lashed it together in a hurry just before going on holiday last year ![]() 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
Ta very much...
![]() Cheers Simon |
MSS Site Sponsor Member Since: 16 Dec 2011 Location: York Posts: 4 ![]() ![]() |
Hello,
These pick up on existing fixings points located behind the trim and sit on the main body of the car using the roof bolts. The trim then gets put back. (no need for drilling) I have attached a picture which hopefully shows where abouts these fixings points are. Hayley T: +44 (0) 844 879 4440 info@mobilestoragesystems.net |
Sorry Simon, took the pictures but completely forgot to post them
![]() The shelf itself is a sheet of 9mm ply with a small batten on the leading edge to provide a bit of rigidity and to stop things just sliding off. It works well for coats and other 'soft' stuff. ![]() Click image to enlarge The rear corners are then supported on two 9mm ply 'legs' that bolt to existing fixing points below the windows. Whilst they work perfectly well, they will eventually be replaced with something slightly more elegant. I plan to fit mesh window guards and then make some smaller metal brackets that can be attached to them at the right height. ![]() Click image to enlarge The front edge also has a strengthening batten and is supported on the dog guard by way of being clamped to a second batten through the mesh. ![]() Click image to enlarge As I said, this was very much a last minute lash-up but it's nicely rigid and does work very well. It was deliberately fitted without drilling any additional holes and the whole thing can be removed in a few minutes. When I get around to replacing the front supports, I'll paint it so that it blends in a bit more. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
