Home > Maintenance & Modifications > Driver side air intake grill fell off
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
As the title says. Luckily I was parked so still have it.
Seems like it was glued but only in one place around the perimeter.
What kind of glue would be best to glue it back on?
Would Sikaflex be appropriate?
Post #288428 7th Dec 2013 7:06pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Hi there, There should be little pins on the grille that push into holes on the wing to hold it in place but they break easily and the grille falls off as a result. Sikaflex would be ideal for sticking it back on as there is no point in buying a new one as it would eventually fall off as well! Smile
Post #288430 7th Dec 2013 7:10pm
kmac
Thanks, this seems to cost only a little more than a tube of Sikaflex....
http://www.ebay.co.uk/itm/Land-rover-Defen...20dbe7da7e
Post #288432 7th Dec 2013 7:20pm
dondiddy
Yes! That would be a good excuse to buy a modified one! Laughing
Post #288449 7th Dec 2013 8:08pm
Defender-Stu
Buy a modified one mate, I have had 3 LR ones and now have a D44 one and much better Thumbs Up
Post #288454 7th Dec 2013 8:31pm
K9F
Seems a regular trend..... Whistle
Here's a solution. Thumbs Up
http://www.defender2.net/forum/topic20098.html?highlight=clips If you go through life with your head in the sand....all people will see is an ar5e!!
Post #288463 7th Dec 2013 9:03pm
kmac
Like to idea of the c clips - might stick with the original grill
Post #288484 7th Dec 2013 10:46pm
