Home > Maintenance & Modifications > Amber LED separate hazard warning lights
BigWheels
I see more utility company vehicles with flashing amber LED hazard warning lights, instead of or as well as indicators.
These are usually mounted in/on the radiator at front and above or below main light clusters at rear. Sometimes side mounted ones as well.
Has anyone got these mounted on a Defender, or knows of a good kit to fit that is suitable, & the wiring necessary? Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #288380 7th Dec 2013 2:19pm
Mobile centre is probably best for that. Not had any but wouldn't be too bad a job. You'd just need an LED relay a hazard light one and hazard light switch. The RDX one for those would be best.
Saying all this others on here can probably advise you best, I don't proclaim to be an expert but if you do it bit by bit it won't be too difficult at all.
There maybe lighting on the market that will have just an on off switch and it's own electrical gubbins to control it's flash rate. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #288386 7th Dec 2013 2:51pm
GUM97
We at work use Emergency Vehicle Solutions (EVS), for all flashers etc. I've got 12 flashers located around my Defender, both front and rear mounted. Not the cheapest, but great quality kit.
Take a look here: http://www.emergencyequipmentshop.co.uk/gr...-c-37.html
Pete An engine to TDi for!
Post #288394 7th Dec 2013 3:48pm
Pete - What do you want them for? Trying to look official? I suppose you go around with hi vis jackets too. Whistle
Rolling with laughter Rolling with laughter ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #288401 7th Dec 2013 4:47pm
GUM97
When it's parked on the hard shoulder of the M6 behind a broken down HGV, they'll be flashing and I'll be in my hi-viz Mr. Green An engine to TDi for!
Post #288423 7th Dec 2013 6:47pm
Knew it. Twisted Evil ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #288438 7th Dec 2013 7:33pm
