Home > Maintenance & Modifications > Frozen central locking
Josh K
United Kingdom 2007 Defender 90 Puma 2.4 HT Orkney Grey
Has anyone else experienced the problem of the central locking mechanism being frozen? Upon trying to open the car with the fob all the doors would unlock except the drivers door. The mechanism sounded like is was trying to unlock but wouldn't. I also trying to unlock it from the inside but didn't want to force it. Once at work the mechanism had sufficiently thawed and I was able to unlock from the inside. Does anyone know which part is likely to be frozen?
On a note for others I can confirm it's not particularly easy to climb into the drivers seat through the passenger side, over the cubby box and without kicking the CB or getting snow everywhere! Whistle 2007 (57) Defender 90 (Sold)
Looking for another to replace it.
The road less travelled.... is a muddy one!
Post #288098 6th Dec 2013 9:30am
landy andy
It is often the grease around the mechanism getting very very thick due to the cold, not it freezing. A good clean with WD40 then regrease with thin grease works well.
Andy
Post #288099 6th Dec 2013 9:34am
BigRuss
Word of caution....
I've had this but it didn't freeze until I started then engin and then shut the doors to remove the snow and then got locked out with the engine running Embarassed
This a problem that all vehicles can suffer from! Russell
2011MY 110 XS USW Black
Post #288119 6th Dec 2013 11:30am
Josh K
BigRuss, I'm guessing you locked yours after you got out with the engine running? 2007 (57) Defender 90 (Sold)
Post #288123 6th Dec 2013 11:46am
landy andy
I think what Big Russ is saying is that his defender locked its self whilst the engine was running and he was not in it. Then causing the issue of keys inside locked car whilst engine running. Ok if your near the spares, but if not...............
Andy
Post #288129 6th Dec 2013 12:13pm
I used "rangoon" oil in the locks and silicone spray on the rubbers and silicone spray on the uppy/downy door buttons Thumbs Up
Post #288133 6th Dec 2013 12:27pm
BigRuss
Correct Andy,
Luckily I was on the drive, unlucky for the wife who I ha to get out of bed after hammering on the door for ages.
It was -20 something outside! Russell
Post #288139 6th Dec 2013 12:58pm
