![]() | Home > Td5 > Refillin R380 gearbox oil |
| ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2967
How about pipe and a funnel from engine bay or a suction pump
| StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246
What you've described above is exactly what I use, bought it out of Homebase for about 12 quid. Saves a lot of hassle.
2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
I've got a garden sprayer for this very purpose. It's slow but controllable and mess free. I've put a short length of rigid pipe in the end of the flexible tube, which helps it stay in place in the filler hole. Darren
| Phatcat Member Since: 01 Nov 2013 Location: W yorks Posts: 98
I've always used a gear oil pump bought from machine mart for about 15 kwid. Looks like a grease gun with a flexy tube on the end. It's quick, clean and cheap.
| Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501
When changing my gearbox oil i feed a piece of plastic pipe from near the brake servo down to the filler hole and insert a funnel into the hose and simply pour the oil int the funnel and let gravity do the rest. 2005 Td5 90 XS
Steve |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6041
So maybe my idea of the sprayer is a good one... Also good for axles & transfer case 1999 Defender TD5 110
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052
Garden sprayer for me too. Works really well if oil nice and warm.
Andy |
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
This /\/\/\ £1 fer a meter of 12mm (ish) clear pipe ,another £1 ferra funnel.You can just about see the filler hole from the engine bay. You can just about do the axles with pipe and funnel,it is a bit slow with the oil being so thick. Pov.spec,ftw. 2006, 110,TD5. |
| Carlosbeldia Member Since: 13 Oct 2013 Location: Cartagena Posts: 43
You can use a hand fuel pump for boats, it costs around 10 pounds here in COlombia, you can find it in any boat store. Mine can fill the gearbox with ATF in about 4 minutes. The transfer goes for about 10 minutes....
"Fill the gearbox with ATF"
Should that not be MTF? Or do you prefer ATF? Andy |
I have a problem here with MTF, it's extremely expensive, about 6 times the cost of ATF (Land Rover one is about 10 times more expensive). My gearbox only used it during 20.000 km (bests of his life, I think, it was really smooth those km). Right now the gearbox have 230.000 km and have some issues, it's going to be done a full maintenance on april 2014, so from then I'll start using Honda's MTF (have a new job right now so can afford the extra cost). With MTF I would think this manual fuel pump must be even faster...
| geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4410
I am a bit of a fan of the oil safe products http://www.oilsafesystem.com/oss-oil-safe/...s-and-Lids think difflock.com sell them here in the UK. They are not the cheapest, but they work flawlessly. I use the hand pumping version with the hook type end for the R380 filler hole, works a treat.
This is the one I have
| kevb Member Since: 03 Apr 2012 Location: AllPackedUp Posts: 34 |
I have the oilsafe pump too, wasn't cheap but must have had it 10 year s now so its paid for itself. very happy with it.
