Home > Maintenance & Modifications > 03 TD5 sidelights
chipmunk
2012 Defender 90 Puma 2.2 HT Oslo Blue
03 TD5 sidelights
Am I imagining things.......? I 'm sure my 90 used to have additional side lights in the main headlight....ie when engine off and lights on the main lights gave off a faint glow? Not dipped headlight but similar light to separate sidelight. Not there now and no fuses blown! May be age related brain malfunction!!!
Post #287640 4th Dec 2013 4:31pm
Martin
Site Admin
Not as standard it wouldn't have, some aftermarket headlamps do have a sidelight bulb fitted.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #287641 4th Dec 2013 4:32pm
chipmunk
Ta Martin...........dreamt it then!
Post #287646 4th Dec 2013 4:41pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Bad earths can sometimes make the lights do weird things! Something as simple as going over a bump can correct the fault as well! Laughing
Post #287648 4th Dec 2013 4:47pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
You're not quite mad ... it may well of had a resisted feed to the headlight bulbs when sidelights were on and ignition also on ... headlight bulbs would of glowed dimly along with sidelight operation.
Standard fitment on nearly all later variants of TD5 and current TDCI .....
Is yours an early TD5 or the later version ? Guns and Landrovers .... anything else is irrelevant.
Post #287651 4th Dec 2013 5:08pm
Martin
Site Admin
The OP did say engine off though, which makes me think it's NOT dim-dip Confused  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #287652 4th Dec 2013 5:09pm
Dave-H
Yea .. but he could be confused Laughing Guns and Landrovers .... anything else is irrelevant.
Post #287654 4th Dec 2013 5:14pm
jimbob7
Mine has done this recently,I had a bad side light bulb/connection,so I thought it just put the headlights on a low setting as well as the remaining sidelight,swapped the bulb, cleaned the connector and the headlights now stays off and only the sidelights come on Question Pov.spec,ftw. 2006, 110,TD5.
Post #287659 4th Dec 2013 5:40pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Perhaps it wasn't a dream.. was the key in position II?
When my light switch melted and stopped working, the sidelights still worked and the headlights had a dim glow despite the switch only bring on position I, it was probably current leaking from position I to II inside the switch..
Post #287682 4th Dec 2013 7:18pm
Some vehicles had the dim dip thing. usually the big resistor under the RH wing breaks causing it to stop.
Post #287698 4th Dec 2013 8:04pm
jimbob7
Engine was running,only noticed coz I saw the reflection in the back of a car,like I say since I swapped the bulb and cleaned the connection everything is back to normal. Pov.spec,ftw. 2006, 110,TD5.
Post #287711 4th Dec 2013 8:25pm
chipmunk
Seem to remember it occurring for the first few years I had the car then just noticed it not doing it. Very confused now, wondering whether to go check resistors and stuff..........or reserve place in nearest OFH?!! Smile Sad
Post #287714 4th Dec 2013 8:28pm
landy andy
My 04 Td5 had dim dip, one day it worked, then I didn't. Think yours could be similar.
Andy
Post #287737 4th Dec 2013 9:38pm
chipmunk
Thank you all.
Post #287790 4th Dec 2013 11:35pm
CEEGEE
United Kingdom 2006 Defender 90 Td5 HT Cairns Blue
I have a 2006 TD5 - when the sidelights are on with the ignition, there is a low level light also on in the main headlight.
When the ignition is off, but the sidelights left switched on, only the side lights are lit.
Not sure if this is right or not Confused
Post #287803 5th Dec 2013 12:53am
