![]() | Home > For Sale & Wanted > [Wanted] Bulkhead spare wheel mount |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
As in the Land Rover one that allows you to mount your spare wheel to the back of the cab?
If so I will see if I can find my old one. Glyn ![]() ![]() |
Hock Member Since: 12 Sep 2011 Location: Yorkshire Posts: 133 ![]() ![]() ![]() |
Thats the one, someone must have removed mine at some point in time
I will see if I can find mine (removed about 4 years ago).
![]() Glyn ![]() ![]() |
Thanks for having a look
Got one sorted
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 462 ![]() ![]() ![]() |
If your current one doesn't work out I think I've got one in my shed from my 90 hard top too. 2.2 90 XS
88" Series One Old Norton ![]() Minerva |
hhmmmffff......As I have 285's fitted on 16 inch rims the offset is too far out, which means the thread bar isn't long enough to reach the wheel
![]() Anyone know of an extension you can buy or would I be best getting a piece welded on ? |
Silly question but have you tried the wheel both ways around?
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1732 ![]() ![]() |
Hi as above really
If you put it so the wheel faces straight forward it will go on. Only reason I know is have a 285 75 15 bf Goodrich all terrain on a boost (which is a wide tyre) and fits no problem with a lot of tread left? I take it your not still trying to use the alloy spacer between the bolt and galvanised holder. Cheers Tom Defender puma dormobile camper |
