![]() | Home > Maintenance & Modifications > Corrosion fix - ideas welcome. |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1830 ![]() ![]() ![]() |
For sealing, I suggest Sikaflex. I've used it on my Defender to seal many areas of leaks, great stuff...
http://www.ebay.co.uk/itm/SIKAFLEX-291i-29...1210962659 ...other suppliers are available.. ![]() Cheers Simon |
i have a cunning plan to seal some holes in the rear tub of my 110 where I've removed the old seat belt mounts in a similar fashion, so I think it sounds ok. In your case, I'd try and treat the corrosion as best you can first, but once sealed in with Sikaflex or similar it shouldn't get any worse. I'd plate and seal from the outside to prevent any further exposure to water and then coat the seat mounting bolts with Duralac to prevent further bi-metallic corrosion. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 269 ![]() ![]() ![]() |
Thanks for the input. I'll use some sikaflex as a sealant/adhesive.
I reckon on getting some new mounting bolts; I'm not optimistic that the old ones will be easy to remove! |
