![]() | Home > Technical > Beeping when pressing the brake pedal? |
| Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677
I have done a search but nothing turned up on this site,
on another site it suggested that this was an indicator that the pads were running low, fronts got done about 6 weeks ago, ive just popped the rear wheels off and there is about a cm on each pad left... anyone got any ideas? |
electrical id say.
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022
Have you checked the brake fluid level? ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
topped up not so long ago as had problems with the hand brake warning light ..
Perhaps that may be an associated issue then, I've had brake pads quite worn and had nothing beep. Having said that if yours is an XS that might well make a difference as mine is a County. ____\We|Will|Win/___
mines also a county, need to change that..
