![]() | Home > In Car Electronics > Kenwood Cubby Active Sub Install |
| Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265
Fits like a glove
| custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21029
Proper job!
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
| cabell Member Since: 20 Dec 2010 Location: Virginia, USA Posts: 33
Looks great. How does it sound?
Sounds really good
But it's discreet which is what I was after. Factory look with no visable wires |
| Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982
Looks great! Please would you post which model this is and where you bought it.
Is it a KENWOOD KSC-SW11 150 WATT? Ta Merlin Last edited by Merlin on 30th Nov 2013 2:19pm. Edited 1 time in total |
| Papa Lazarou Member Since: 11 Sep 2013 Location: West Midlands Posts: 40
That looks great Tiger
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
Hi Tiger,
The Kenwood website lists the side to side dimension as 280mm and a cubby is only 270mm wide yet your install appears to be the exact width ? Does the Kenwood sub get wider above the base ? |
Yep, I know the dimensions don't add up but in reality it works really well.
When I bought it I thought I'd have a small overhang each side but although it's fractionally wider it doesn't show. Also it fixes through through the cubby from the inside it sits flat. |
Cool, thank you
Been and double checked and base is beveled in so it sort of narrows a touch.
Anyway like I said I took a risk and it worked better than I expected |
It's a Kenwood KSC-SW11 active subwoofer
Was £119.95, which seems reasonable |
Thanks, did that come with all the cables?
Merlin |
All the cables are in the box.
It doesn't have RCA cables included though if you going to use a pre out ( I did) but it does include a cable to splice into your speakers. If that makes sense? |
Thanks, I've dropped a line to Just Kenwood asking them if they supply the right cables.
Merlin |
