![]() | Home > Maintenance & Modifications > wheel arch liners |
They look good
![]() Stop a lot of noise from the rear wheelarches (especially in the rain) as well I suspect ? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
myonehere Member Since: 03 Mar 2009 Location: Worcester uk Posts: 153 ![]() ![]() |
they do indeed - although the heavy sound-deadening kit does that too ...
Can you get 110 rear arch liners?
'dunno - but made mine myself with rubber sheet - and some cast off lorry mudflaps
Norm4n Member Since: 31 Aug 2012 Location: Surrey Posts: 329 ![]() ![]() |
Where can you buy these from?
Assume they are very robust and wont crack up with large stones clattering into them? |
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
Yes I'd like to know if they fit 110 and where are they from?
dondiddy Member Since: 13 Nov 2012 Location: Hamilton Posts: 224 ![]() ![]() ![]() |
The front liners you can get from Landrover as they come fitted as standard on some models. The rears look to be made from HGV spray suppression mudflaps which you can buy from a commercial motor factors or the likes of Ebay. They are very robust and should not crack and will reduce road noise and the rain in the wheelarch sound you get driving in the rain! You would have to cut them down to suit then find a means of attaching to the inner wing. Shouldn`t be to difficult to do and would be a very worthwhile mod that won`t cost the earth to do. They should also help protect the rear crossmember from crud as an added bonus which can only be a good thing!
yes - as said below [above] = lorry mudflaps- trimmed carefully they need minimal fastening as they are held by the lip above the 'eyebrows'. Served me very well on the last two Defenders. No reason you cant fit to 110 as well... and yes, stops all the muck going up over the chassis crossmembers too. Front ones are held by the existing screws holding the inner plastic wing |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 265 ![]() ![]() ![]() |
Also very interested in this mod, as I have discovered corrosion holes around the rear seat mounting brackets in the wheel arch of my 110. I can only think from stones and crud being thrown up into the arch from the tyres. Thanks for posting.
Here's the front arch liners.
Only problem is they cost around £152 each ![]() ![]() Click image to enlarge |
mine cost about 50p I think -
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
I'd like to do that as well. We drive on lots of gravel roads, and the noise from the gravel being flung up and hitting the wheel arches can be quite loud and gets on one's nerves after the first 100km.
I have heard of people who use a spray-on rubber? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2787 ![]() ![]() |
Don't all defenders have these fitted? I've never seen one without? They separate engine bay and the wheel so there has to be something there. Both my 200tdi 90 and tdci 90 and tdci 110 all had them fitted anyway. Yes it would be fairly easy to trim a big standard car mudflap and bolt it to the front of it I guess too Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
All Defenders have inner wheel arches as standard An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" ![]() |
