![]() | Home > Puma (Tdci) > Rear Recover Point Defender 90 |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
3 options:
Mount to the rear crossmember. Good enough in a straight line pull (NATO jaw mounts to the 4 central holes) but questionable from an angle. Mount to the chassis. Such as a Jate ring. I know what you mean about the lack of reinforcing but I've never seen or heard of anyone tear their chassis rails with a recovery. If you mount two then you have the option to spread the load further. Mount to both. Such as aDixon-Bate adjustable or Southdown. Essentially this will give you the strongest possible anchor but by tying to the chassis rails you inevitably compromise departure angle. The D-B setup is even more extreme than the OEM one but you get more height. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
I looked at the LRDE video and it looks to me they have a angle iron below the chassis but I cannot see any additional support to the front like when you have a standard tow bar.
That is off course an option make a very short towbar and reuse the additional supports to the chassis. It help to give some more protection to the tank too. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
KarlB Member Since: 08 Feb 2010 Location: Canberra Posts: 91 ![]() ![]() ![]() |
Thanks for replies alantd and roel. But, gee wiz, I expected more replies. What do others on the forum with Puma D90s do about rear recovery?
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
Be carefull when fitting rear Jate rings, they come very close to the plastic fuel tank. The lashing eyes are also awkward to remove as they have to be sawn off. They are bolted on before the tank is fitted, presumably because of the clearance with the fuel tank (the head of a bolt is thinner than a nut and a few threads of protruding bolt). The Jate rings will need to be threaded one side. Jate rings that use a bolt with a nut won't work! Hope this is usefull.
That's interesting - I never bothered to look on my old 90. The 110 is perfectly accessible. My OEM and D-B adjustable tow hook (with the chassis ties) mount to the same holes so how does that work on a 90? I can't imagine that fitting the OEM tow hook is a tank-out job ![]() + New Defender 110 First Edition |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 ![]() ![]() ![]() |
I took the approach of buying a Safari Equipment 2" receiver that bolts onto the rear cross-member, and then sits just underneath it, keeping out of the way, but allowing you to attach a recovery point when needed (or towball when needed). Peter
2008 SWB Truck Cab 1952 80" Soft top |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
i like these and have one on the disco - remember for towing its not type approved
Safari Equip 110 I presume the 90 may be similar
Yep, the 90 version looks just the same
![]() 2008 SWB Truck Cab 1952 80" Soft top |
Thanks to all who replied now have a bit more to think about.
Cheers KarlB |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8347 ![]() ![]() ![]() |
LRE hontion we ran std two hitches on 90 and 110s
i run a southdown rear tow pack on my 110, better protection for the tank, no loss of departure angle plus option for a tow hitch or a recovery eye. i moved the electrics up into the rear 'PTO' hole in the chassis Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Just ordered the safari equipe one to tow my Sankey...are the recovery recievers the warn 2" ones
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 ![]() ![]() ![]() |
they are indeed, any 2" attachment will fit. we've got one from Scorpion racing, everything is the same, apart from the sh*t powdercoating. 110 Tdci Double Cab
How does it line up? Do you have a plate that comes out of the 2" hole and points up to keep the NATO in line with the holes in the crossmember? Will that be strong enough (there are folks who have bent their crossmember towing a Sankey). If your NATO is in line with the 2" bracket (the strongest position) won't it be too low? I have to admit, though - not having a plough on the back is quite appealing. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
