![]() | Home > Td5 > Has anyone fitted a 6 speed box to a td5 engine |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6018 ![]() ![]() ![]() |
I think Ashcrofts were, at some point looking at a Puma 6 speed to TD5 conversion. Not sure if it ever happened. Maybe worth giving them a buzz? 1999 Defender TD5 110
Defender_mad1990 Member Since: 14 Oct 2013 Location: Tipton Posts: 4 ![]() ![]() ![]() |
Will give them a bell tomorrow mate
Cheers phil |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6205 ![]() ![]() ![]() |
Failing that, unless it's already got one, a 1.2:1 transfer box will increase the leg length a bit.
I've got one in my (Td5) 110, made a huge difference. |
epictrail Member Since: 21 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
Which vehicle is that transfer box if that from?
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Or go for a Ashcroft transmissions 1:1 Transfer box?
Glyn ![]() ![]() |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 631 ![]() ![]() ![]() |
Generally speaking the preferred option to improve a TD5's road performance is to fit the 1.2 transfer box and get a decent engine map.
I agree with the 1.2 box- but depends on what your desired choice in tyre size is. Anything less than 33s (265/75/16) and you will still be sat at 2500-2600rpm at 70. Going from my Puma Defender to the gf's Discovery Td5 I feel like I am revving the t***s off it when on the motorway at 65mph.
1.2 box is so popular because there are hundreds of them floating around from broken Discoverys (normally fetch about �100) where the 1:1 box will need to be bought from somewhere like Ashcrofts (�550). Handy link from the Ashcroft site: http://www.ashcroft-transmissions.co.uk/calc/ratio_calc.html. Glyn ![]() ![]() |
How difficult is it to swap the box's?
Couple of hours work..... just need to disconnect drive shafts, disconnect linkage unbolt from the gearbox and then do the same in reverse to fit
![]() Glyn ![]() ![]() |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
I believe that the 6 speed MT85 out of Aston martins/corvettes etc can be made to fit, read somewhere that a guy in America fitted one to a range rover classic so, similar transfer box with an adaptor plate?
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton Last edited by grafty99 on 26th Nov 2013 10:14pm. Edited 1 time in total |
just looked and used the Ashcroft ratio calculator the MT85 only drops the 70mph RPM by ~ 100RPM 2002 90 Td5 Station Wagon
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
yeah, a 1.2 box is the way to go.
It's really a fuel saver and ear saver on a long trip. epsecially when you are doing 110 to 120km/h, you'll appreciate it. the lt230 is the same fitting, so you don't need to worry about it not matching. so it's a 1.41 box out drop it and drop in the 1.222 and you're done. it's purely a mechanical exercise, physically. do bear in mind, if you had cruise control via the ecu, it will now only work in gear 4. so a 'speedo healer' can be fitted or you can get a cruise control kit. pulling away in gear 2 might not be so easy now, if you are used to that. but anything on a slight decline slope, you'll pull away great in 2 and make good acceleration. The defender has migrated, leaving the owner behind. |
m_plewes Member Since: 17 Feb 2011 Location: Thirsk Posts: 11 ![]() ![]() |
That's because the 6speed box is fitted with the 1.2 transfer box. Just fitting the 6 speed box with 1.4 transfer box would make hardly any difference. The gain from the 6 speed is still having a low 1st gear. 1.2 transfer box on a tdi or td5 isn't great for setting off fully laden or towing. |
I believe the MT85 is different to the MT82 fitted to the puma
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
