![]() | Home > Puma (Tdci) > Owners manual |
| dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188
I have PDF work shop manual TDCi 2.4 my 2007 > pm me your email IL send to you. it`s 75MB
Matthew |
Josh K
Its on it way Matthew |
| Josh K Member Since: 01 Nov 2013 Location: Herefordshire Posts: 266
Can you try and send it again, it's not come through. I've double checked the address I sent you and that's all good. 2007 (57) Defender 90 (Sold)
Looking for another to replace it. The road less travelled.... is a muddy one! |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
you'll be lucky to be able to send a 75mb attachment.
do a search, the forum member "DGARDEL" has them on a sky drive for download. |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Hopefully this will work!
http://api.viglink.com/api/click?format=go...3940996068 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
K9F is that one not for the 2.2? 2007 (57) Defender 90 (Sold)
| x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327
The OP asked for a User manual which can be found on LR Topix;
http://topix.landrover.jlrext.com/topix/vehicle/lookupForm Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
My fault your mistake..... If at first you don't succeed..... https://skydrive.live.com/?cid=4bc2d89c85c...C171%21550 If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
have been out uk on work is all sorted |
