|  | Home > Technical > Electronic question |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686  | The Puma uses 11 bit CAN protocol over a 500k bus.
 Only the IPAC and EMS are on the CAN network. There is no BCM. The Wabco ABS and Alarm (10AS)modules use serial links (Analogue) to communicate with the IPAC. The pin out on the OBDII socket is the industry standard. There is no pollen filter, Wiring diagrams as well as workshop manuals are available on this forum if you do a search. The Visteon wiring diagram you are after? Is it the pins out or the circuit board diagram? Both of which are on here somewhere IIRC.   HTH  | ||
|  24th Nov 2013 1:40pm |
| martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422    | hello and thank you lorryman
 Well you post a question go off to asda do shopping come back question answered day gets better only one thing and please forgive my ignorance whats an IPAC and where does it live. I am after and would like to buy (not after something for nothing) a good workshop technical manual with fault finding charts wiring diagrams dtc codes etc as I plan on keeping the car for the next 10 years or until Vauxhall start making the mk2/3 cavalier again. Any recommendations would be appreciated as new to ownership and new to this whole internet forum thing. again thank you martin | ||
|  24th Nov 2013 2:14pm |
| Jonno1968 Member Since: 24 Oct 2013 Location: Leicestershire Posts: 245      |  What on earth are you two on about?! Good luck with that then!      | ||
|  24th Nov 2013 2:15pm |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686  | IPAC is the instrument cluster, binnacle.     If you search workshop manual and wiring diagrams you will find them on here, they were put up by dgardel.  | ||
|  24th Nov 2013 2:19pm |
| martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422    | Ah Instrument Panel Assembly Cluster    I wondered that but was ent sure, again thank you will go off looking for diagrams this is to nights home work  | ||
|  24th Nov 2013 2:33pm |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686  | Work shop manual:   http://www.defender2.net/forum/topic687.ht...hop+manual
 Wiring diagrams and manuals: http://www.defender2.net/forum/topic4403.h...hop+manual  | ||
|  24th Nov 2013 2:41pm |
| ARC99 Member Since: 19 Feb 2013 Location: North Yorkshire Posts: 1831      | what's this, office speak for Land Rovers   Don't make old people mad. We don't like being old in the first place, so it doesn't take much to  us off. Richard | ||
|  24th Nov 2013 2:42pm |
| dorstsmith2 Member Since: 06 Aug 2012 Location: On the third rock from the sun in dorset Posts: 188      | Cant all bad at lest he drives land rover to go and repair fiat commercial vehicles (fix it again tomorrow)        yes i had misfortune of having drive fiat for work | ||
|  24th Nov 2013 4:02pm |
| martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422    | Thanks all for reply`s
 just finished my bit of the house work off to look at suggested links for the rest of the evening martin | ||
|  24th Nov 2013 4:57pm |
| MartinJC Member Since: 12 Jul 2014 Location: Gauteng Posts: 13      |
 My my2013 defender have recently developed a fault on the  alarm system, the interior lights come on when nogotiating uneven terain and the Alarm triggers sporadically when armed. i believe it to be a wiring issue though the vehicle only has 3k on the clock. i connected the Faultmate MSV 2 to the car,  but it does not seem to be able to find the 10AS any idees? | ||
|  24th Jul 2014 4:22pm |
| mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605      | Sounds to me like a door sensor or bonnet sensor is at fault, if it's going off randomly when armed check the bonnet sensor, in the summer the metal will contract and expand due to scattered cloud turning the sun on and off like a hair dryer...  simple way to test the bonnet sensor is to unplug it and leave it..
 although I don't think opening the bonnet turns on interior lights? | ||
|  24th Jul 2014 7:55pm |
| Hal Member Since: 04 Jun 2014 Location: Bedford Posts: 91    | I had a similar problem - interior light stayed on and alarm not happy.  It was just a metal tab not pushing a door switch enough.  Just bent the tab a bit more - easy fix. | ||
|  27th Jul 2014 6:37pm |
| MartinJC Member Since: 12 Jul 2014 Location: Gauteng Posts: 13      | Thanks!  I found the problem on the front passenger door, could not bend the Tab as it is to thick, had to make a spacer. | ||
|  27th Jul 2014 8:49pm |
| Posting Rules
