Home > Maintenance & Modifications > remote start |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
I think most remote starts keep the doors locked and not driveable.
If you press the throttle it cuts out. It's quite common in certain US states either to cool the car down (a mates Dodge in Houston was fitted with one as standard and apparently he could start it from a few miles away) or to warm the car up. In fact, I've just come back from Florida and there was an advert (Ford I think) for new cars with remote start to clear the snow and warm the car up. Why this was being advertised in Florida I have no idea! Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
22nd Nov 2013 5:02pm |
a lot tend to have handbrake switch if brake taken off engine outs out ..much like run lock that lorrys police cars and ambulances have |
22nd Nov 2013 5:26pm |
A remote start system is very similar to the run lock system operated in police cars etc (and some trucks). If any pedal is pressed the engine cuts out, so can't be driven until the key is in the ignition. An engine to TDi for!
"Land Rover- Proudly turning drivers into mechanics since 1948" |
22nd Nov 2013 5:53pm |
defninety Member Since: 13 May 2010 Location: Warwickshire Posts: 37 |
I think you will probably see over the next few years more and more manufacturers offering remote start purely for warm up, de-icing and passenger comfort reasons . FBH's etc tend to be unreliable at times and with the advent of stop/start technology on most new vehicles nowadays, all the required sensors etc for safely doing so are already in place. |
22nd Nov 2013 6:02pm |
Yes I agree with you there, it used to be a bit of an old school thing to help start up when you had oil like treacle and nowadays it is recommended by manufactures in the hand books purely as a safety feature. Hence on a lot of modern autos you need to press the brake pedal and modern manuals the clutch and/or brake before it will allow you to crank the engine. |
22nd Nov 2013 6:08pm |
DELETED
22nd Nov 2013 6:09pm |
NOT HAVING A DIG AT YOU BUT All the greeneys keep telling us to switch engines off while stationery at lights or crossing etc to help save the planet... now we gonna have everybodys cars running warming up outside they houses . wonder what they say to that!!!! perhaps there go round keying everybodys car not just 4x4s like some were in London a while back |
22nd Nov 2013 6:10pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2105 |
It's actually illegal to leave an unattended vehicle running. I don't care if you do, just pointing that out
Mo The Land Rover 90 - Many are called, few are chosen. |
22nd Nov 2013 8:51pm |
^^^^ it's illegal to leave an unattended vehicle running on a public highway not on your own property. Therefore when you start your car to defrost whilst it is sat on your drive way, you are breaking no laws!
22nd Nov 2013 9:28pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
To answer the original question: Yes
Here's my solution: You'll need to leave the keyfob inside the dash permanently.. I believe it's needed unlock ECU to allow the car to start, this will compromise security.. The electronics are actually pretty simple.. a simple cheap remote starter kit will do (£50) The interesting part which will resolve all issues as mentioned above is an actuator.. I.e: This thingy: Install a simple 12v actuator to lock the clutch pedal in position when depressed. This solves the problem of leaving the car in gear and general wear and tear, also acts as a layer of security if correctly installed with a hidden switch.. E.g: You press the clutch all the way down, flick a hidden switch to power the actuator causing the clutch to lock in place. Actuators don't use any electricity when powered so battery drain isn't a concern. Fit a switch on the clutch to enable the remote started only when the clutch is depressed. Sounds complicated but it's only about • ~6 wires • An actuator ( a waterproof one ) • 4 bolts to stick it to the bulkhead • Hole cutting into the clutch pedal arm for the actuator arm • On-Off-On switch Alternatively you can install a simple lever next to the handbrake to hold the clutch depressed ) |
22nd Nov 2013 10:12pm |
Will.I.AM Member Since: 16 May 2013 Location: Hertfordshire Posts: 357 |
for those who are interested i now have a price. I was told by Neil of Creative Car Sounds, he could do it for 450inc vat. This includes a remote stop alarm system linked to the fob as well, so for up to 200 yards, you can turn the engine on or off. It also includes a imobalisation system as well which cant be undone. I know some defenders have it already but another deterent or electronic head ache for clever theives is not a bad thing.
27th Nov 2013 4:32pm |
<delete> - boy this thread is moving fast
27th Nov 2013 4:44pm |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 |
Did anyone get this fitted?
8th Dec 2014 9:32pm |
Doesnt matter if it 2 wheel drive or 4x4 , all your turning in the drivetrain is input (1st motion shaft ) and laygear ( 2nd motion shaft ) , and thats the same for any car
Normally only reason for starting clutch down is safety agree with clutch down putting extra load on crank thrust bearing , normally only small brg surfaces |
8th Dec 2014 10:25pm |
