Home > Puma (Tdci) > Engine rattle?
Page 2 of 3 <123>
AlanH
Australia
Thnx Lorryman and Yes Caterham you may well be right. I'm off tomorrow on a good run towing the van so over the next few days it'll get a good steady workout.
What I won't be doing is wearing my hearing aids as it's definitely quieter without them. Laughing
AlanH.
Post #283603 19th Nov 2013 11:30pm
Caterham
I hope you have an enjoyable drive
Post #283606 19th Nov 2013 11:46pm
WAFU
England 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Caterham wrote:
what I'm getting at here is does everything else function as you'd expect it to.....engine response good when changing gears etc. I would suggest (and its only a suggestion) that if everything else is as you'd expect then perhaps other than injector learn it's simply the defender noise in part due to a lack of sound proofing?
Hi Caterham
Yep everything else is working fine, no lurching etc. its a good point you make and is probably just me. Ive not had a modern diesel with no sound proofing yet and am only judging the excess clatter based on the loan defender not having any and my mates with having a lot less. I researched old threads on here before posting and found that some clatter could be taken out with changing to better quality fuel - thats made no difference, then tried Lucas diesel additive to lubricate upper valve train - no difference and have finally brought some Millers Ecomax fuel additive as a lot of people swear this quietened the motor down. Ill let you know if that works?!
Still going to book her in though just to be sure and its got a couple of other issues that need looking at.
By the way anybody who uses Millers - its on offer at Opie Oils and you can use our club discount too Wink
Post #283656 20th Nov 2013 9:52am
Caterham
good luck in resolving it one way or the other.
I've had 3 years of trying to track down that 'pinking' sound. there's been so many variables along the way I really don't know whats what anymore. I believe everything is pretty much as it should be and I still have the pinking sound which seems to vary for no obvious reason however I'm happy its within normal tolerances which I don't beleive it was before.
Post #283662 20th Nov 2013 10:04am
WAFU
Did the injector learn not work then? Trying to gauge what to expect based on your experience.
Post #283673 20th Nov 2013 10:57am
Caterham
the injector learn so far as I'm concerned improved things but most certainly didn't make the engine silent.
so far as I'm concerned the noise went from a kind of 'loose' rattle to a more surgical / pricise rattle.
this may be completely unrelated however you've mentioned the engine sounds fine while stationary you might just want to try loosening off the adjuster on the handbrake drum to ensure you've got some clearance (obviously marking the point its at presently first so it can be returned - might be a cmplete red herring but its easy to do)
following my experiences (and I still don't knew for sure if I have an issue) I'd give all the wiring under the bonnet a gentle jiggle in case theres a wiring issue and remove and replace plugs ensuring they're all clean etc.
and a check of the propshafts - do they have grease nipples and grease?
Post #283683 20th Nov 2013 11:24am
WAFU
Ill check all of what you've suggested.
Thanks Thumbs Up
Post #283763 20th Nov 2013 5:35pm
Caterham
It's all easy stuff and can be done in very little time so as far as I'm concerned it's worth doing / checking. Good luck and please keep us posted.
Post #283845 20th Nov 2013 9:23pm
munch90
When we code injectors you have to do them in firing order not cyl order. 1342 so on programming screen 1=1,2=3,3=4,4=2 if that makes sense this is for 2.4 transit engine so guess it may be the same as puma.. Not sure if same on all machines
Seen people get this wrong few times..
Post #283896 20th Nov 2013 11:26pm
Caterham
WAFU - just wondering how you're getting on....enjoying or infuriating?
Post #286637 30th Nov 2013 10:41pm
WAFU
Well the mechanic had a test drive and said it was completely normal. I used the demo model I had as a benchmark upon which he explained that too will become rattly when its done some more miles.
Its strange as the motor sounds very quiet when cold but when it gets to 45 DegC (Scanguage) it suddenly goes tappy like a switch has been turned on!
During its next service it will have the injector relearn procedure carried out which the mechy said may help but not a lot.
Until then.....
Post #286712 1st Dec 2013 11:14am
Caterham
In time you may succumb to the same engine up grades as myself manufactured by Dynomat and Focal......
Post #286714 1st Dec 2013 11:18am
Caterham
One other thing I've been meaning to do is to get someone to drive mine past me while I'm outside cos everyone else's always sounds quieter from outside compared to mine inside Confused
Might just give me piece of mind.
Post #286715 1st Dec 2013 11:21am
WAFU
Caterham
I used the car today and whilst driving I wondered what the rattle would sound like from outside as well. I lowered the window whilst it was rattling at its loudest and the noise dramatically reduced Shocked almost to the point that I could no longer hear it?
I wasn't going very fast so wind noise etc was not really applicable in lessening the rattle. Question
Post #286775 1st Dec 2013 4:55pm
Caterham
Very Happy. Thumbs Up all fixed then?
I have to Laughing cos my dad understand how it sounds so good from the outside but a bag of nails from the inside Laughing
There's nothing like them......defenders.
Post #286777 1st Dec 2013 5:01pm
Page 2 of 3 <123>
