Home > Puma (Tdci) > Radio on 2007 Puma...
RED-DOT
My radio loses its preset station when i switch the ignition off and goes into search mode and usually locks on to Radio Fadeaway and hisses like hell. It has been into dealer 3 times and they say this is normal... i don't think it is but does anyone else suffer this annoyance? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #28163 26th Mar 2010 7:53pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Are you sure its not YOU upsetting it for it to be hissing at you Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #28164 26th Mar 2010 7:58pm
RED-DOT
It is so annoying and it never retunes into a station i like unless it is called Python F.M.!! 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #28165 26th Mar 2010 8:00pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
Did you save your favourite stations manually (i.e. find the channels and then hold in button 1 until it saves it etc.) or do you use the AUTO button to fill the six presets? The only thing I can think of is if you did the latter then perhaps it finds the six strongest every time you start the car. I changed my radio some time ago, but the only time it ever searched for channels was after unplugging the battery. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #28179 26th Mar 2010 9:30pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Mine holds onto its presets (I think). That said, I really only listen to a couple of stations but they always seem to be there Smile
I don't think it's normal. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #28304 28th Mar 2010 8:15pm
jav-uk
England 2014 Defender 110 Puma 2.2 SW Alpine White
Just I thought....
I think the ABS thingy ma bob controller is very close to aerial on the XS, it ruins the radio reception if the
aerial is not fully extended. Had this issue on mine. Aerial was still slightly down, only by a couple of inches, reception was totally useless until I realised.
Also, try playing a CD and see if you have the same issue when you cut the engine. Paul
Pondering a New 90 Commercial
2020 Evoque
* 2014 110 SW JE Stage 2.
*2010 110 Utility. JE Stage 2.
*2007 110 SW
*2003 90 JE Stage 2.
*2000 90 SW
If its not leaking it ain't full.
Post #28371 29th Mar 2010 3:29pm
Cibit
Sounds like its been wired wrong. The radio needs a constant low current to save all the preset stations. If it does not save them something is wrong.
Give your dealers hell young man Thumbs Up Oh and if you could get someone to video your conversation with the dealers to post on youtube. Rolling with laughter 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #28373 29th Mar 2010 4:41pm
niglyn
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Yeah, mine did that.
I just changed the whole car Laughing
Left it to the dealer to sort out (I doubt they bothered)
Hey, I'ts not my old one is it?
Post #28374 29th Mar 2010 4:59pm
RED-DOT
I bought it new and every time it goes in for our many "enhancements" i try to get the dealer to fix it and every time i pick it up they say it "only does it in certain areas"... but it does it ALL the time with me and it goes to a non station that hisses like hell.... it also must have the constant feed as it would lose the memory and need re-coded? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #28375 29th Mar 2010 5:05pm
niglyn
I fitted the 12s wiring on my 07 and did not need to re-code the radio when re-connecting the battery.
It always lost it's presets.
The new LR has the same radio but does not suffer the same problem, so our radios were faulty.
Post #28376 29th Mar 2010 5:12pm
RED-DOT
Thanks, i just emailed my supplying dealer and told them basically it has gone on too long and i want a new head unit ASAP... i don't think it should do this on a �26k car. We will see what they say. Has anyone had thiers replaced? 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #28378 29th Mar 2010 6:26pm
lrdxb110
United Arab Emirates 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
My service manager mentioned somebody took delivery of their brand new 90 last week and the right hand side speakers were all faulty (damaged), LR replaced all the speakers under warranty. Not the same problem like yours Red dot but you should raise the issue and have a brand new radio installed! Thumbs Up '08 LR Defender 110
'08 Mini Cooper S - Sidewalk
'86 MB 500 SL
'79 MB 450SEL 6.9
Post #28383 29th Mar 2010 7:18pm
i know this may not be the easyest or most sensible route however if you wanted to the original radio is so easy to remove and replace with an aftermarket unit i.e. Sony or Kenwood ect for �50 upwards infact you could have a better radio anyway. litterally with mine it was plug and play (Kenwood) however my unit was more complicated than your every day CD player. that way you'll sort the problem and have a nice UPGRADED Radio/CD player at the same time. Just an idea Wink
Post #28510 30th Mar 2010 8:44pm
any news on your problem so far RED-DOT Question
Post #28875 2nd Apr 2010 9:32pm
RED-DOT
No, i emailed them to say i want a new head unit and it is currently at LR Warranty department and to be honest i don't use my Defender from one week to another... thanks. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #28876 2nd Apr 2010 9:36pm
