Home > Maintenance & Modifications > Anti Roll Bars
Page 1 of 5 12345>
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
Anti Roll Bars
Has anyone fitted up-rated ARBs to assist with normal road driving to reduce roll? If so; any recommendations? BM52
Post #139687 16th Apr 2012 10:44pm
Porny
Site Sponsor
Re: Anti Roll Bars
I'd personally keep the standard front ARB - but use uprated mounts (SuperPro are my chosen option), but I would upgrade to a thicker uprated rear bar - again with uprated mounts.
I have also played around with solid ARB mounts, which make a huge difference even with standard bars - but aren't really suitable for road use.
You'd be more than welcome to come and drive my Puma Demonstrator.
Depending on your driving style, there are a few other options....
Ian
Post #139719 17th Apr 2012 7:19am
bm52
Hi Porny and thanks for the advice.
I think you have summed up my thoughts, it's the back that seems to roll more. I have been thinking about this for a while. I don't drive aggressively but i don't dawdle either. I think the springs, standard LR road springs, are probably fine for me as well so I think I will find a stiffer rear ARB and take your advice on the Super Pro bushes.
Cheers BM52
Post #139926 17th Apr 2012 8:26pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
I have 28mm diam ARB and Koni raid shocks on back to reduce roll with camper on the back. All from Extreme 4x4. 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #139977 17th Apr 2012 10:21pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Old thread resurrection:
Anyone recommend a uprated rear roll bar for a 110? I've seen the 28mm offerings from Terrafirma and Extreme 4x4x and wanted to hear people's experiences of them or if there are any others.
Post #283438 19th Nov 2013 10:36am
epictrail
No one use uprated roll bars Question Laughing
Post #283541 19th Nov 2013 8:45pm
bm52
I have a 90 and bought an uprated rear ARB plus SuperPro bushes [from a D2 sponsor] and it has made a big difference. Corner with confidence, no issues off road and whent fitted with quality dampers [Koni for me] I think it makes sense. I do a lot of road miles from motorways to B roads and at all times the 90 feels planted and secure with some body roll but much improved from standard. BM52
Post #283545 19th Nov 2013 8:54pm
epictrail
Uprated as in 28mm??
Which make of bar did you buy?
thanks
Post #283551 19th Nov 2013 9:14pm
bm52
From memory the bar was 25.4mm. BM52
Post #283554 19th Nov 2013 9:30pm
noworries4x4
I have got the biggest anti roll bar that Extream (Scorpion) do along with heavy duty springs the back end of my 90 does not move well planted, but remember it is fully loaded all the time. Also you have to change the bush mounting plates to accept larger bushes and bush retainers.
 If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #283587 19th Nov 2013 10:38pm
epictrail
Thanks.
Thats the one I want to get but Extreme have no stock till January. Big Cry
Post #283617 20th Nov 2013 12:15am
rustandoil
What about the X-Eng X-deflex rear anti roll bar? Possibly the best of both worlds....
Post #285752 27th Nov 2013 7:52pm
epictrail
Rather expensive though Rolling Eyes
Post #285753 27th Nov 2013 7:55pm
rustandoil
......true
But i have to spend my cash on something Very Happy
Post #285774 27th Nov 2013 9:27pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
I've now got a standard ARB on the front and Extreme 4x4 1" ARB on the rear.
Neither were fitted when I got the truck and the effect is greatly to reduce body roll, especially when overtaking when you can have relatively quick changes of direction.
As I've said before, the torque settings for the three fixings make a huge difference to the ride.
Per the Haynes manual (68, 40, 30 Nm?) is quite relaxed but do them all up f tight as did the bloke who changed my fuel pump, and it's almost undriveable. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #285778 27th Nov 2013 9:36pm
Page 1 of 5 12345>
