Home > Td5 > HELP needed headlight failure
tazmarkuk
England 2000 Defender 110 Td5 HT Chawton White
Hi all, my headlights didn't work when coming home this evening, I don't have dip or main beam on both sides, I do have the spots still working on main beam, am I right in thinking, the light switch has packed in. All help & guidance appreciated, can't check till the morning when it's light.
Regards Mark
Post #283503 19th Nov 2013 6:41pm
VeeTee
Netherlands
Yes, probably the switch melting because of too much amps going thru. Happens frequently, see my post earlier here. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #283508 19th Nov 2013 6:51pm
dondiddy
Scotland 1998 Defender 90 300 Tdi ST Nato Green
Hi Mark, Yes you are correct! Its a common Defender fault as the headlights are wired directly to the switch without the use of a relay so the switch eventually burning out is the end result. Once you replace the switch it might be worth modifying the headlight wiring to incorporate a relay to take the load off the switch to prevent it happening again in the future. Hope this helps!
Post #283510 19th Nov 2013 6:54pm
tazmarkuk
Thanks guys all help appreciated, good excuse to tell work I've gotta go home before it gets dark.
Post #283512 19th Nov 2013 7:14pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Is this all defenders? Mine is a 2004 TD5
Post #283513 19th Nov 2013 7:16pm
there was a link on the forum to a company who make a plug and play loom complete with relays for defenders ... WTF they don't fit them at standard I don't know but they are available for peeps who want a quick "proper" fix
Post #283514 19th Nov 2013 7:17pm
VeeTee
Netherlands
Link for the relay loom here. Cheers, Vincent
MySite
Post #283516 19th Nov 2013 7:30pm
cheers VeeTee Thumbs Up
Post #283517 19th Nov 2013 7:31pm
VeeTee
Netherlands
One of the first things that happened in my Defender ownership, the melting light switch - so one of my first mods, installing the relay loom along with a new switch.
Thumbs Up Cheers, Vincent
MySite
Post #283519 19th Nov 2013 7:36pm
tazmarkuk
Just been looking at new switches on fleabay, there are cheap switches at around a tenner and OEM at �25, does anyone know if there is actually any difference in quality between them.
Mark
Post #283520 19th Nov 2013 7:40pm
kipperthedog
Lucas is the one you need. Got mine from a seller called Adventure 4x4 on ebay. This was the best price I could find. About �22. I have seen reports of the ones in blue boxes lasting weeks before melting!
Will do the relay mod in the spring I think!
Post #283691 20th Nov 2013 11:59am
