Home > Td5 > Td5 rough running when starting
v8bobber
United Kingdom 2008 Defender 110 Puma 2.4 DCPU Java Black
Hi All,
When I start my Td5 it is very lumpy for a few seconds. I have changed the injector loom previously and am wondering whether it is down to the cold weather as it seems to be worse then
Glow plugs perhaps?
Dave
Post #283373 18th Nov 2013 11:36pm
Orangeboy
Think most diesel cars/vans I have had sound broken when first started in te cold weather
Does it start easily without lots of cranking over ?
Post #283376 18th Nov 2013 11:40pm
v8bobber
no she starts first turn. All other "modern" diesels i know seem to be even running from the moment they start
Post #283377 18th Nov 2013 11:42pm
landy andy
Td5's are often a bit rough on cold start as they only have four glow plugs but five cylinders.
Andy
Post #283378 18th Nov 2013 11:44pm
v8bobber
ah yes i'd forgotten about that. I seem to remember it being quite tricky to get the caps back on so not sure how hard they are to change
Dave
Post #283379 18th Nov 2013 11:47pm
Orangeboy
My golf tdi sounds very rattley when it first starts in the cold
Maybe its as broken as out defender lol
Post #283435 19th Nov 2013 10:19am
Martin
Site Admin
Make sure you let it glow long enough. They are a bit lumpy as said because of the missing plug.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #283436 19th Nov 2013 10:20am
v8bobber
I do let the pre heat light go out before i start it. It must be down to a temp sensor I would have thought as it stays on for longer when it is cold.
I remember with a Tdi I had years ago you could give it a double blast of glowplugs but you can't do that with the Td5. I'll take them out and test them when I get a minute. It wouldn't surprise me if one or more of them is broken.
My previous Td5 didn't have this problem so just made me wonder....
Dave
Post #283580 19th Nov 2013 10:22pm
johnszs
United Kingdom 2004 Defender 90 Td5 XS CSW Alveston Red
Mine sounds like its running on 4 for a few seconds until compression starts the 5th when temps are below 3 degrees, i assumed the air temp sensor and or glow plugs need replacing 2004 TD5 Defender 90 xs station wagon
Post #283586 19th Nov 2013 10:37pm
Millsy94
England 2003 Defender 90 Td5 PU Aintree Green
have you checked the flywheel sensor?? its just behind the started motor and if there is an issue with either the starter or the sensor the electronic interference can confuse the sensor
Post #283589 19th Nov 2013 10:41pm
johnszs
Havent thought of that, but i will have a look on the weekend 2004 TD5 Defender 90 xs station wagon
Post #283594 19th Nov 2013 10:44pm
And it seems that the Td5 glowplugs fail pretty regularly.
I fitted 4 new ones into my 90 when I fitted the last head (about 4 or 5 months ago), when I changed the head (again...) last weekend, I metered the plug out, and 2 had failed (OK, they were cheapy eblag ones not genuine, whether there's a difference in quality)
Post #283638 20th Nov 2013 8:49am
jimbob7
Cheers Jim.....for reminding us to buy oem plugs in future. Thumbs Up Pov.spec,ftw. 2006, 110,TD5.
Post #283687 20th Nov 2013 11:50am
Carlosbeldia
Columbia 2001 Defender 110 Td5 SW Epsom Green
I had same problem here, but my "cold" starts goes around 30°C, so I think is not a weather thing. My problem was the no-return valve in the filter line. It was damaged and let small amount of pressure went during night (not enough for difficult start but enough for rough start first 5 seconds) letting some air to go in the lines. 10 pounds after and smooth as a baby...
Post #284107 21st Nov 2013 9:19pm
