![]() | Home > In Car Electronics > Halfords Speaker Range |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
Over priced and limited selection, 10cm is the size you want. (For easy installation anyway)
Have a look at these http://www.ebay.co.uk/itm/KENWOOD-KFC-S109...5d3c4b08c6 Or these http://www.justkenwood.co.uk/car-audio.aspx/kfc-e1065-speakers I have the more expensive ones but the later model, there are Pioneer iirc that are a tad more powerful for the size but depending on HU you've chosen you really want the same brands on most things if you can. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
I went to a locally recognised audio specialist who recommended Kenwood to me for HU and speakers and an Alpine active sub.
I listen to most genre of music and I am very please with the quality and general output. I had 2 speakers blow [after a slight shorting issue ![]() Regards BM52 |
"Slight shorting issue"
![]() ![]() ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Let's just say I was listening to some nice music and some twit decided to re-route a couple of wires with a coat hanger up the back of the bukhead and .........
![]() ![]() I've undertaken a lot of wiring on vehicles and I think that was the first time a fuse was blown - live and learn. BM52 |
johnnyd Member Since: 13 Apr 2013 Location: Chippenham Posts: 1006 ![]() ![]() ![]() |
Is that live and learn or 'LIVE and learn'
![]() ![]() ![]() JD 2008 TDCi 2.4 XS CSW |
Always best to remove the fuse, trouble is a lot of us are guilty on that one! And to lazy to disconnect the battery even.
![]() On the bright side at least you didn't short and Amp cable! Otherwise you'd very quickly end up doing a bit of welding! ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Hi Steve
Which of those two links would you say were the best speakers ? Also are you sure i want 10cm, the outer grill of mine measure 13cm? JD 2008 TDCi 2.4 XS CSW |
Yes, 10cm the size is measured on them by the mounting hole diameter not the speaker outer diameter.
![]() If you want more bass as standard I would say these: http://www.justkenwood.co.uk/car-audio.aspx/kfc-e1065-speakers They go down to a lower frequency to the ones I have hence a bit more bass, mine are slightly higher frequency but I have the Sub to make up for it. The ones above should be a good all rounder. Funny enough Kenwood seem to have reduced their range a little for the 10cm speaker range, unless it's just stock availability on Just Kenwood. They give you free delivery and 1year warranty. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Hey Steve, do you know max depth available ? Looking at these
http://www.inphaseaudio.co.uk/products/spe...ge/xt42ii/ 30 quid from tesco JD 2008 TDCi 2.4 XS CSW |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1455 ![]() ![]() ![]() |
In Phase
Oh
![]() What have you got Jim? JD 2008 TDCi 2.4 XS CSW |
It's a bit tight for a 13cm (a lot more modification to fit anyway) but a 10cm for depth should be okay what ever depth they are. It's the OS that is the tighter area.
Cannot give you any guarantees though I'm afraid but should be okay. Closest runner for me personally I'd choose bar what I currently have is these: http://www.halfords.com/webapp/wcs/stores/...yId_265869 Love the looks of them too, drool* ![]() What ever you get keep the recipt and just place it in position in the hole if it's fine both sides your good to go. If not just take back for a swap or refund. ![]() I would stick to premium brands though. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
Johnny - Jim and I are arch rivals when I tomes to brands.
5" Focal polly glass but I did do some butchering for them to fit
