![]() | Home > Puma (Tdci) > extra battery for security or alarm |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
Or just earth inside the battery box and run a 2nd cable inside the car?
yes only thing cutting main feed does not set off alarm then .. so they still might do damage opening bonnet or what ever .. simply alarm to protect cable may stop this as it would go off instant and they got motion sensor so if they tried towing away
True, all immaterial if you haven't move the alarm sounders though
just a thought do people run extra earth in thick or thin cable ..if thick its got to be as heavy gauge as standard and earth to inside box and engine (otherwise if you did not know main wire had been cut and tried to start defender you have all load from starter running through body or even if they tried to start it .. not a good idea if its thin wire then must be fused as same if you didn't know wire cut trying to start starter load would light cable up .. not a good idea Last edited by munch90 on 16th Nov 2013 10:27am. Edited 3 times in total |
simply fit alarm has its own siren built in and small enough to mount hidden away |
you say about extra earth.. what about cutting positive cable still runs out of battery box side underneath
sure the positive has 2 wires one to fuse box underseat and one to starter cutting close to box (one cut to both cables) as sure they come out of same hole ( not same hole as earth ) in battery box. or even if fuse box and main starter wire come out of different holes still don't take long to cut both still all dead and no alarm and bonnet gone ( unless bbus sounder fitted but not all have ) |
You can get BBUS on eBay for £15
Just search "Range rover p38 alarm" ![]() AMR4971 Connector is already in the loom, plug and play ![]() |
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 285 ![]() ![]() ![]() |
I brought from Ebay a small sounder with built in battery that activates if the supply to it is lost, hidden in the body work and makes a lot of noise.
Can be switched off with a built in key when working on the Landy or going in for work. 2008 Defender 110 XS CSW Volvo XC40 Recharge Triumph T120 BMW R1300GS G0UBX |
AWOL Member Since: 31 Oct 2013 Location: UK Posts: 222 ![]() |
I've been thinking about this and I'll have a length of thinnish wire + inline fuse in stock on delivery day before working out what to do longer term. My logic is that it'll probably be possible to fit this quickly without needing to worry too much about sourcing different battery clamps and the such like. |
NOT all have connector for bbus and if it hasn't you need the part of wiring loom |
