Home > Td5 > Help, water in ECU!
gor30
Russia 2004 Defender 110 Td5 SW Aintree Green
Help, water in ECU!
Hi, friends!
Water in ECU. ECU- damage.
I need ECU NND500020 SoftNNW501300 4195
Thank's!
Post #282123 14th Nov 2013 2:30pm
On ebay you'll find the NNN000120 ECU and the NNN500020 ecu
Not many on there at the moment, but keep looking, they come up sometimes.
Also you could try Ben @ www.venom4x4.co.uk I bought one off of him a few weeks ago.
both the NNN500020 and the NNN000120 will do the job.
Post #282519 15th Nov 2013 8:37pm
roel
If you buy a second hand one make sure it is a from a defender as once it is programmed for a discovery you will not be able to use it in a defender and visa versa. Roel
2003 90 Td5 (2009-now)
Post #282581 16th Nov 2013 4:33am
Porny
Site Sponsor
Roel,
Your mistaken.... any NNN500020 ot NNN000120 can be reprogrammed to suit either a Defender or Discovery application. It is the earlier MSB****** ecus than can not be easily changed.
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #282590 16th Nov 2013 8:04am
gor30
Thank's all of You!
I find ECU on ebay.uk - Mastaz
Post #282623 16th Nov 2013 10:18am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
I have repaired several TD5 ECUs after drowning. In case of newer NNN it is good idea, in case od older MSB type ECU, it is cheaper to buy anouther ECU. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #282680 16th Nov 2013 3:09pm
roel
Porny wrote:
Roel,
Ian
OK learned something again. Mr. Green Roel
Post #282738 16th Nov 2013 7:12pm
gor30
I need ECU NNN500020 SoftNNW501300 4195
Post #282843 17th Nov 2013 8:37am
MadTom
Can you open the ECU and make pictures of both sides of board inside? If it was drowned, there will be probably some small burnt parts. These can be replaced and the ECU repaired.
I may have some spare ECU - I have to look. But if you buy a new or used ECU, you will have to eneter in the ECU codes of your injectors, the right fuel map and have learnt it the security code from imobilizer. So you will need some some diagnotics.
And one possible problém - you are outside of EU, so all packages has to come through the customs. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #282846 17th Nov 2013 9:43am
