Home > In Car Electronics > Factory Radio Removal
johnnyd
Hi All
Is there a way to get the Factoru HU out without a proper tool ?
JD 2008 TDCi 2.4 XS CSW
Post #282440 15th Nov 2013 4:02pm
kharnsflair
I took the dashboard out around it on a TD5 (bless Defenders). Hopefully a newer one isn't much harder.
Post #282448 15th Nov 2013 4:25pm
Yes, I'll PM you the details or I could pop it out for you? Thumbs Up _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #282449 15th Nov 2013 4:28pm
johnnyd
I would like to try in the next 30 mins Steve if you could PM me 2008 TDCi 2.4 XS CSW
Post #282451 15th Nov 2013 4:29pm
Cheshire110
if it helps you, halfords will (if you ask correctly) let you use their keys (make them think you want to see the connections on the rear to help you buy something from them)
or you can buy them for like 3-5, they're usually open til 8 or later Cheers, David
Post #282453 15th Nov 2013 4:33pm
PM'd Thumbs Up _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #282457 15th Nov 2013 4:39pm
johnnyd
Well I couldn't get to Halfords today as Chipnum was closed due to a big accident, so i made 2 x removal tools from a wire coat hanger....Pioneer fitted and firmware updated Smile
Post #282779 16th Nov 2013 8:46pm
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #282782 16th Nov 2013 9:01pm
alsalloumabdul
Kuwait
Re: Factory Radio Removal
johnnyd wrote:
Hi All
JD
Nope, you need two proper steel/plastic sticks.
Post #285025 25th Nov 2013 10:05am
K9F
johnnyd wrote:
so i made 2 x removal tools from a wire coat hanger....Pioneer fitted and firmware updated Smile JD
Where there's a will there's a way! Thumbs Up
Johnny hope you're still happy with the truck! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #285028 25th Nov 2013 10:20am
Cheshire110
You can remove the whole centre panel (the bit with all the switches and clock on)
Just need the right torx head and then use a large flathead screwdriver to pry it forwards at the edges, not too hard.
You can then push in the bits that hold the radio into the cage manually Cheers, David
Post #285041 25th Nov 2013 11:03am
