Home > For Sale & Wanted > SOLD Norwegian container |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 |
Ah, the ubiquitous saf jar
14th Nov 2013 11:19pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6046 |
I've got a couple of these. great things. ideal for laning days/weekends out
Interesting that even when new they have that stained yellow colour.... I just thought it was all the cups of tea we drunk on ex that tainted them! |
15th Nov 2013 8:18am |
Les Brock Member Since: 20 Mar 2012 Location: Stroud, Glos Posts: 148 |
Or full of orange "screeetch"
The stuff you sould use to stip paint |
15th Nov 2013 8:54am |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
PM on the way. Craig Rogers
2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
18th Nov 2013 5:36pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 760 |
Now sold. ONE LIFE, GET IT!
19th Nov 2013 10:41pm |
Sorry for dragging an old thread back up.
For those that got one of these, how long should it keep stuff hot for? I want to use this for the first time so I left a kettle full of boiling water inside for about 5 hours to test and it's stone cold? None of the seals are leaking and ok it might work better if it was full, but would of thought it would work better than this? Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
7th Mar 2014 8:47am |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2642 |
They should keep food/fluids hot for 8 hrs. BUT it's the same as a flask, if left unopened for that time its perfect. Everytime you open it you will lose heat. Everytime you remove some of the hot liquid/food and replace it with cold air, it speeds up the cooling process.
So a kettle of boiling water stood no chance of staying hot over a 5 hr period 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
7th Mar 2014 5:51pm |
5 hours?? Us skinny badges had drunk all the tea by that time and refilled with the next lot!
7th Mar 2014 7:08pm |
Aint that the truth. Hence why the fleet of veh was always broke!!! 110 D250 SE HT
7th Mar 2014 7:55pm |
But that was the thing. I put a (large) kettle of hot water in there just to test. It remained unopened for 5 hours. When I opened it, the water was stone cold, not even a hint of warmth left. It was like someone had emptied it and replaced it with water from the cold tap. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
10th Mar 2014 7:40am |
Dave Member Since: 30 Aug 2007 Location: Wiltshire Posts: 165 |
Mate, I think that you may be expecting too much. The best way to use these is to pre heat with a few litres of water for 10mins then remove it and then fill as much as possible to leave as little space as possible. The fuller they are, the more effective they are. Expect no more than an hour for small volume and no more then 3hrs when full (maybe 4?). They are the same principle as a flask of course. Check the seal in the lid and that all of the taps are closed and screwed up tight. Wet items keep hotter than others and best for water rather than actual made brews due to stewing
10th Mar 2014 8:06am |
Yeah, beginning to think that.
It was bought to replace the 3.5l Thermos pump containers that I normally use. These keep water hot enough for drink making for at least 10 hours, but are a pain as they are not sealed and of course don't hold anywhere near as much. I think I'll just use it as cold water storage and revert back to the Thermos' Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
10th Mar 2014 8:10am |
