![]() | Home > Puma (Tdci) > Gearbox tech bulletin |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
I'd be interested in that as the selecta linkage is in the gearbox
![]() Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2680 ![]() ![]() ![]() |
Nope, haven't heard/read anything about this --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
borderterrier Member Since: 09 Dec 2011 Location: Surrey Posts: 1677 ![]() ![]() ![]() |
My MY 13 went in for a few jobs yesterday, one of which was a stodgy shift from 1st to 2nd. I know they are all like that
Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2789 ![]() ![]() |
if someone has some concrete info or can get a copy of the bulletin then i'd be very interested to read it!
(maybe that technical will help, border terrier?) Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
I will ask tomorrow David
defninety Member Since: 13 May 2010 Location: Warwickshire Posts: 38 ![]() ![]() |
Here's a copy of the TSB, hopefully this has all the info you need.
![]() Click image to enlarge ![]() Click image to enlarge |
Apologies the quality of those pics weren't too good! I've added the pdf in my gallery that you can view/download.
Thanks fella
No problem, hope the mod improves your issue.
cheers
![]() Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6214 ![]() ![]() ![]() |
"no tools required"
![]() ![]() I suppose chewing some gum to stick in there requires no tools ![]() |
My assumption is that it means no "Special" tools required, after all bodge tape etc are all standard issue nowadays!
Spencer72 Member Since: 29 Oct 2013 Location: Western Australia Posts: 5 ![]() ![]() |
I have a 3 week old 110. Just confirming, if I complained about the change of gear issue on my first schedule service this should be covered under warrantly?
Yep, all Pumas still under warranty should have this fix carried out.
If you are friendly with your stealer, you can try and get it done for free/reduced rate if your landy just came out of the warranty period. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
