![]() | Home > Technical > CB radio |
| Josh K Member Since: 01 Nov 2013 Location: Herefordshire Posts: 266
Have you checked the SWR reading? Ensure you've got a good earth on the ariel then check the SWR, adjusting the ariel to get the lowest possible reading. There is a guide from Jim at www.4x4cb.com 2007 (57) Defender 90 (Sold)
Looking for another to replace it. The road less travelled.... is a muddy one! |
| gbmud Member Since: 02 Jun 2013 Location: Sussex, UK Posts: 167
It is quite usual for the signal meter not to register anything unless someone else is transmitting close enough to be heard - in such a circumstance there is no signal, it is not like a mobile phone. With the squelch turned down you should hear 'white' noise, turn it up till there is no sound and then, when someone transmits, you will hear their transmission.
HTH Chris |
