Home > Td5 > Do you need to change the clutch after tuning?
roel
I installed a second hand PSI power box. (yes I know a proper remap is better etc. but at a price off a tank diesel in holland (not UK) I could not resist trying it and it works gooood)
So good in fact that my clutch is not up to it. I can fully accelerate without the box switched on but when I switch on the box I have to be carefull with the throttle. On full acceleration the clutch starts slipping at about 1800 rpm.
My 90 has done about 90 k miles it could be the original clutch and it sometimes makes some noise after being parked for a few days, so it could be on the end off it's life.
So my question is:
Is a standard clutch upto the task if a td5 is tuned and is my clutch on the end off it's life and would it start slipping next month anyway or do I need to look for an uprated clutch?
The funny thing is that last Sunday playing off-road I didn't notice the clutch slipping at all and I am driving 35" simex.
 Roel
2003 90 Td5 (2009-now)
Post #281501 12th Nov 2013 9:47am
Standard clutch should be quite adequate for a TD5 with a PSI Powerbox, is does sound as though you need a new one.
I know of a TD5 Disco2 which has been running a PSI Powerbox and standard clutch for 60k+ miles with no issues whatsoever.
Post #281507 12th Nov 2013 10:10am
roel
I was thinking the same but as there is many experience here with tuned td5's I just want to know it for sure. Mr. Green
It would be a pity replacing my clutch and then find out that a standard one isn't strong enough.
How many HP/torque would a standard clutch hold? Roel
Post #281517 12th Nov 2013 10:45am
Clutch on my 110 slips like Censored when I boot it (tuned with VGT turbo and 1.2:2 t/box)
When I built it i had the wrong slave cylinder in it, so it was like having your foot resting on the clutch for the first 3000 miles of its life.
then the fuel pressure regulator leaked, so covered it all in diesel (worth checking that on your one... the diesel doesn't take long to "burn off" once you fix the regulator)
So mine needs doing too. I'd say if you have a high power tune, or hi load (as in, towing, big tyres, over geared etc) then the clutch needs to be in tip top condition.
Post #281529 12th Nov 2013 11:09am
adafish
United Kingdom 1984 Defender 110 300 Tdi DCPU Stornoway Grey
and do it ENGINE OUT....find that the easier way.. Putting Dreams on Drives at JLR Solihull..
Post #281538 12th Nov 2013 11:38am
I have never heard of a TD5 clutch in good condition slipping, irrespective of power and/or load, and if it slips I would always take it as a sign that something was wrong.
With my Disco2 I have often towed up to 3.5 tonnes with no slippage. The day I towed 140 tonnes it was slipping a bit to get the load moving and there was a very hot clutch smell, but it was fine afterwards!
If you had a seriously radical tune and greatly overloaded the clutch I would expect the DMF to fail first. There is I believe a small number of TD5s running around the 250bhp mark as far as I know on standard clutches.
One of our 'in-forum' tuning gurus is probably best placed to answer this question.
Post #281554 12th Nov 2013 12:25pm
+1 Thumbs Up
Post #281573 12th Nov 2013 2:22pm
roel
Is it not possible like how I did it with my Camel Discovery, just move de gearbox 25cm backwards to get just enough space to change the clutch? Roel
Post #281583 12th Nov 2013 3:40pm
If you've got a decent trolley that will carry the 'box, then yes.
Removing the engine saves lying on your back for hours on end (enless you've got a ramp/pit)
Post #281595 12th Nov 2013 4:42pm
roel
Whistle I did it in a real workshop on a bridge from my parts supplier Twisted Evil
Byt if you work on the ground I think the most time you will be on your back anyway to loosen everything under the car. The time just to change the clutch and pressure plate is 30 minutes?
Would you replace the DMF also? Or only if you see anything wrong?
And what to look for with the DMF? Roel
Post #281666 12th Nov 2013 8:33pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
How much did you tow?? 140 tonnes! Bow down
What did vosa say?
Post #281673 12th Nov 2013 8:46pm
grafty99
I think you'll find he was moving one of his hobbies (not the caravan!) 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #281683 12th Nov 2013 8:55pm
Actually it was only 124 tonnes, I checked. Dead class 47 diesel loco needed moving a short distance in a rail yard.
It was actually easier to move than you might think.
Post #281750 12th Nov 2013 11:04pm
grafty99
Are you up at newberry this weekend roger? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #281752 12th Nov 2013 11:07pm
Ha, thought it was you! Yes, Friday to Sunday.
Post #281758 12th Nov 2013 11:21pm
