Home > Puma (Tdci) > Rattle coming from driver's door, possibly near latch?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi all...
My 110 has developed a really annoying rattle/squeak that appears to come from around the door catch on the driver's side. It is particularly annoying as it manifests itself only when driving slowly over bumpy terrain or roads, and due to the position isn't something that I can easily troubleshoot while driving.
Before I take off the door card I figured I'd ask if anyone else here has experienced something similar.
It almost sounds like the door card itself squeaking, however it stops when I open and shut the door w/o releasing the handle, not allowing the lock to catch (albeit while driving slowly!).
Post #281176 11th Nov 2013 9:32am
munch90
check where the window bolts to the regulator the 8mm bolts come loose in the plastic bits that stuck to glass .. that's what mine was .. had a rattle looked couldn't fit it then window dropped out and down .made it easy to find then !
Post #281186 11th Nov 2013 10:22am
eutek
Shocked window dropped out! Want to avoid that, I'll have a look at those bolts when I take the card off.
Had something similar happen on Mrs. Eutek's Merc, the rear windows on her model's year have an awful design, the mechanism eventually fails, whether you use it often or not, had one window fall into the abyss of the door and break while lowering it.
Post #281205 11th Nov 2013 12:42pm
Cheshire110
Happened to me! Except it shattered in the door when my passenger tried to raise it.
Fixed under warranty but they didn't get all the glass out and it rattles around in the door now! Meaning to get it out sometime Cheers, David
Post #281227 11th Nov 2013 2:06pm
g13non
Ireland
I have the same rattle and on initial investigation it seems that the metal rod connecting the door handle to the latch has started to vibrate. There looks to be plastic guides which normally keeps this rod on track. They have worked themselves loose. I am waiting for the next service to get this sorted.
Post #281237 11th Nov 2013 3:22pm
munch90
just in case you don't know .. sometimes you have to move window up or down to be able to get at bolts and BE CAREFUL if they electric .. seem a few trapped fingers in workshop
Post #281293 11th Nov 2013 7:14pm
eutek
Well - took the door card off, drove around a bit to better locate the source of the rattle, to discover that it isn't there!
I did glue one of those plastic rod guides back in place, but that wasn't making much noise at all.
The rattle appears to be up around "ear height". Almost like it is coming from the pillar between the driver and passenger doors, or maybe even the driver doorframe up near the window track. No window rattle though, that and the track itself are snug.
It isn't the seatbelt lug either, checked that. Very odd...
Post #291334 18th Dec 2013 9:15am
Romadog
How about the bolts that join B pillar to roof ?
Rattly washer ??
Post #291339 18th Dec 2013 9:32am
I have one of those too! In four years of motoring I still haven't found out what it is that is rattling. It does seem to stop if I open the door though.
Solution - turn up the radio.
Post #291343 18th Dec 2013 9:49am
Jim_Bean
I'm just leaving the dealership now after having a bunch of tweaks and repairs done.
The drivers window rattle was found to be the connecting rod between the lock and the door handle. On the rod are a couple of plastic pads that stop the rod rattling against the door. The irony being that it was these plastic squares that had rattled loose and were themselves rattling against the inner metal sheet.
Might be the same for you guys.
Post #291389 18th Dec 2013 12:35pm
mk1collector
Told you Mr. Green
Post #291393 18th Dec 2013 12:48pm
eutek
No, athough I did find one that had come unglued. Glued it back in place, slightly less rattle now but the one by my ear is still there.
It does stop if I open the door, but hard to drive like that. Laughing Pehaps it is related to the bolts that join the b-pillar to the roof...
Post #291423 18th Dec 2013 3:05pm
Romadog
Quote:
Told you Mr. Green
Perhaps...?! Whistle Mr. Green Thumbs Up
Post #291433 18th Dec 2013 3:44pm
eutek
So... sorted. Mark Smith in Bicester discovered the source of the rattle. Seems the catch on the door had worked itself a tiny bit loose, you could barely feel it - but that was enough to make the door rattle like mad and send the vibrations up to ear level.
Post #327014 29th Apr 2014 6:32pm
