![]() | Home > In Car Electronics > New Speakers Installed |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
Sounds great, photos would be great if you could get any. Especially the HS8
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
HMARR Member Since: 04 Jun 2013 Location: New Zealand Posts: 56 ![]() |
Sure thing - here are some pics. I'm so impressed with this setup. The HS8 bolted in seems to work really well with the chassis. It seems to come through the whole car you can really feel it - without being too overpowering.
I've left the speaker covers on the Infinity - as I'm enjoying the new look, however the intention is to replace the covers with the original Land Rover ones as I really want to keep things looking hidden / original. ![]() ![]() ![]() ![]() ![]() ![]() mate, my car is looking dirty in these pics! Last edited by HMARR on 11th Nov 2013 9:45pm. Edited 1 time in total |
Looks great.
![]() Now you just need to push the boat out and buy a second for under the seat the other side. ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ Last edited by custom90 on 11th Nov 2013 9:58pm. Edited 1 time in total |
Then some chromie spinners. B!tches in the front, b!tches in the back and some neon underneath!
Hydraulics is what you need! Or air bagged, pull up to the lights and sit it on the floor.
![]() Well the Americans would anyway.... ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
mees Member Since: 04 Mar 2011 Location: sdijk Posts: 38 ![]() ![]() ![]() |
Hmarr
How did you route the wires of the subwoofer? |
Hi Mees,
Sorry for the late reply - been AWOL. I'm not sure how the installer routed these - but it looks like they go under the mid seats, under the carpet in the back and around the right hand side of the drivers seats - all hidden under carpet. - sorry not very specific, but I hope this helps! |
Thanks
Chocolate Member Since: 18 May 2012 Location: Berkshire Posts: 153 ![]() ![]() ![]() |
Hi Hmarr, Mees,
I have the same HS8 kicker, mounted it in the same place. I routed the power cables along the base and in to the battery box. The sound and Power off cable across the floor and along by the seat belt, down past the hand brake and up under the carpet in to the dash. I have a TD5 so took the dash apart to run them. I also put sound dynamat and foam under the carpet, this gave enough space to route the cables. Sound from the kicker is fantastic made a huge improvement. ![]() Steve recommended it and thanks for it. ![]() I have fixed the little remote to the cubby box. They supply a long cable for this, but as it's just a 3.5mm jack you can get shorter ones. The sound cables you do have to extend. Wayne.. 110XS CSW TD5. |
Glad your happy with my recommendation Wayne.
![]() ![]() ![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
