![]() | Home > Maintenance & Modifications > Scangauge and OBD Socket |
From 3 years ago....
![]() If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Nobby Member Since: 09 Aug 2012 Location: Wiltshire Posts: 444 ![]() ![]() ![]() |
Mal,
Thanks for that, I managed to pop back the OBD but cannot work out a way to either pull the OBD clear or route the actual Scangauge connector so they will have space to fit. I must be missing something, can't see the wood for the trees..... ![]() Gary _______________________________ Puma Defender 90 |
You're welcome. It is fiddly but I initially manipulated mine so it sat behind the original mounting orifice. Nevertheless I have subsequently moved mine for added security and made it very difficult to access.......
http://www.scantool-direct.co.uk/16-pin-ob...tAodRh0AFg If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
Thanks, I'll go and have a play when the rain stops.
![]() Puma Defender 90 |
Josh K Member Since: 01 Nov 2013 Location: Herefordshire Posts: 266 ![]() ![]() ![]() |
I fitted my Scangauge II on thursday and was struggling but found a solution. If you unscrew the Torx screw that is holding the OBD bracket, then use a screwdriver to release the OBD port from its metal bracket you'll have more room to move it. I did have to move a relay just so I could get the OBD port past it then could attach the plug. Hopefully the photo below helps
![]() Click image to enlarge You can see the OBD port connected to the plug to the right of the last relay. ![]() Click image to enlarge I routed my cable behind the steering column. I have read some posts on this forum that show slightly different ways to attach the cable to the port but can leave a slight bulge in the fusebox cover. Luckily this doesn't! 2007 (57) Defender 90 (Sold) Looking for another to replace it. The road less travelled.... is a muddy one! |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
Use an OBD " Y " connector. It has 2 female connector and 1male connector. Move OBD plug to behind speaker. Plug into Y connector. Route 1 of the limbs back into fuse box and with a bit of gaffer tape etc: it an be fixed in the original OBD socket position. The other limb of the Y connector is then available to plug the Scanguage in. It is then easy to plug the vehicle into a diagnostic computer as the OBD connector is easily reached, but remember to unplug Scanguage when using diagnostics as it can screw up the readings etc.
![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Josh K and WelshGas,
Thanks for the information and pictures, all sorted now safely behind speaker only need to get the Y connector. _______________________________ Puma Defender 90 |
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 675 ![]() ![]() |
Just an inoffensive Q, why are people still buying scanguage, when you can get good bluetooth OBD2 connectors and phone apps like Torque?
So much better than what's offered by scanguage and no wires that need routing? Cheers Steve |
Because my phone is just that, a phone! LANDYWATCH
Steve,
No offence taken will all do things our own way, I had looked into various options and it's the way I wanted to go. Also as WelshGas said, my phone is just that and I do not connect my iPad to my vehicle, that's in doors or a bag. Also it will stay hard wired in position and I don't have to try and multi task ![]() Puma Defender 90 |
+ 1
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20977 ![]() ![]() |
If trying to use the WiFi connectors on iPad do you have to have an app too or does it work through browser path?
Some extra info especially live info would be good. How about security I assume it's not something that can be left connected all the time like the Ultra/scan gauge. ____\We|Will|Win/___ ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 ![]() ![]() |
Just got on of these for the FFRR from Canada as not released yet in the Bluetooth version over here I'm testing it for them
![]() Click image to enlarge IID tool from gap with ipad and iPhone app Don't know if it can be used all the time But great bit of kit A must for clearing faults ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
Looks interesting, please let us know how it goes.
![]() ____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
