Home > Puma (Tdci) > Smoke on startup and knocking?
YORKSHIRELAD
Hi lads. I have Blueish smoke when starting from cold and it's running like a bag of spanners. Sounds loud from low revs. I have it booked in but they can't look at it until wednesday. Does anyone have any ideas what it might be?.
Cheers,
Richard 1963 Series 2A truck cab
2008 110 SW
Post #28072 26th Mar 2010 8:28am
bob neville
Have a read here for the blue smoke on start up - seems common.
http://www.defender2.net/forum/topic2764.html
Bob
Post #28083 26th Mar 2010 9:33am
AndrewS
But the bag of spanners could be this. Check your vin number, if its before Vin# 9A767162 you could get a new engine.
Title: 2.4 Puma Engine Knock Noise.
Type: LD - Defender - All Years - Special Service Messages - Engine
Name / Part No: SSM38792
Info Type: Service Bulletins
Version No: 1
Date Uploaded: 21 Jul 2008
Models: LD - Defender
Last Modified: 21-JUL-2008 09:44
Category: Engine
Symptom: 497000 Engine Noise
Content Issue: Heavy audible knocking heard on start up.
Cause: On start up oil pressures can cause the piston cooling jets, (PCJ), to latch into a zero flow condition. Due to hysteresis effect in design the jets do not unlatch until the engine is warm and the oil pressures lower again. During this time with no pressurized oil jet flow to the lower pistons / cylinder bores, overheat and scuff conditions / damage can occur.
Action: Replace the engine assy but ensure only engines post serial # ELD00080707063602 are used.
This condition will not occur on vehicles post assured Vin# 9A767162.
Engines post the info above are fitted with modified PCJ internal springs and this issue is now closed.
http://www.defender2.net/forum/topic472.html
http://www.defender2.net/forum/topic1070.html?highlight=engine 130's have feeling's as well you know Smile
Post #28095 26th Mar 2010 10:29am
YORKSHIRELAD
Thanks for your replies lads. The vin is before the one you posted Andrew.I'll keep you posted after it has been to the dealers next week. Ta 1963 Series 2A truck cab
2008 110 SW
Post #28113 26th Mar 2010 1:15pm
AndrewS
Copy and print my previous post and take it with you Thumbs Up 130's have feeling's as well you know Smile
Post #28116 26th Mar 2010 2:02pm
YORKSHIRELAD
I have not been driving it this weekend, and just went out to start it up and smoke was blowing out of the back and I'm sure it's only running on 3 cylinders?. Crying or Very sad . I need it to get me to work and back until thursday... 1963 Series 2A truck cab
2008 110 SW
Post #28291 28th Mar 2010 5:54pm
YORKSHIRELAD
How do lads. The dealers have recognised the fault and agree that it is running bad and smoking. They don't know the exact cause and said that they think it might be leaking fuel somewhere , and so he said that they have to contact LR, which won't be until tuesday. I don't know...........
2008 110 SW
Post #28849 2nd Apr 2010 5:02pm
AndrewS
Did you print out the info in my post and give it to them ? 130's have feeling's as well you know Smile
Post #28873 2nd Apr 2010 8:48pm
YORKSHIRELAD
I did Andrew thanks, they know of this problem but don't think that it's the fault at the moment. To be fair to them it's more of a misfire than a loud knocking, like running on 3 cylinders and huge ammount of smoke coming out of the back. So much that people have been flashing lights and telling me to pull over!. I did point out that it's similar to the bulletin in that when it warms up runs ok and there is no smoke but for now they don't seem to be going down that route. I'll let you know what happens, cheers
2008 110 SW
Post #28891 3rd Apr 2010 6:41am
AndrewS
At start up after being stood for a day or two does the vehicle feel like its shaking its self to bits Question 130's have feeling's as well you know Smile
Post #28898 3rd Apr 2010 9:01am
Grockle
are you waiting until the glowplug light has gone out before cranking? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #28901 3rd Apr 2010 9:09am
YORKSHIRELAD
It does shake yeah, thats why I thought it was only on 3 cylinders, the smoke it kiks out is crazy. And yes I always wait for the glow plug light to go out. Cheers,
2008 110 SW
Post #28910 3rd Apr 2010 12:47pm
Glynparry25
Mine did this and it turned out to be the EGR.
Glyn
Post #28914 3rd Apr 2010 2:09pm
YORKSHIRELAD
Well almost two weeks after leaving the Defender with the dealers,I got a call this morning to say it's ready. The problem was thst last time it was in they did a software update, and the final part of this didn't install properly. I'm told it's running cock on now. Strange one that?
2008 110 SW
Post #29684 13th Apr 2010 9:19am
Grockle
lets hope so Richard,let us know
good luck 2.4 90 XS
Post #29685 13th Apr 2010 9:28am
