Home > Maintenance & Modifications > Fitting "O.E." Defender Drivin Lights
Pickles
We have optioned the driving "O.E." Driving lights on our new "90". Part No. LR006815. These will of course be fitted by the Dealer prior to us taking delivery.
I see these lights are not compatible with the lamp guards or the front bumper step (chequreplate) options, neither of which we have, and from the image of the driving light in the '13 Defender catalogue, it appears that the "factory" position for these lights is on the outer side of the headlights on the bumper bar?....which to me, would look a little "out of place"? (And may also affect/get in the way of, the headlight beam?)
We don't have a Bull Bar/ A Bar etc, so the bumper is the only place where these lights can be mounted.
Does anyone know whether this driving light "kit" comes with fitting instructions, and if so, does it give any measurements as to where the hole is to be drilled into the bar to mount these lights?
Cheers, Pickles.
Post #279589 5th Nov 2013 12:40am
Tiger
Post #279603 5th Nov 2013 1:15am
Pickles
Tiger, Thanks. From that diagram, does it appear that the lights are not mounted on the bar, but on a bracket, mounted on the body, behind the bar?
Cheers, Pickles.
Post #279607 5th Nov 2013 2:26am
Tiger
The disruptions show a bracket attached to the bumper. Drilled through the top of the bumper
Post #279608 5th Nov 2013 2:40am
JWL
Looks more like two positions, outside of the lights or inside the lights. All depends on whether you drill through the top of the bumper using the template and fix with bolts showing on the top or you fix the bracket on the rear strengthening brace which then has no visible fixing.
Post #279609 5th Nov 2013 2:45am
Honker
 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Here is ours when new
Lights are pretty good and the mounting position is a little odd looking. Since replaced with some small Durite lights.
Stu
Post #279618 5th Nov 2013 7:24am
Pickles
Honker, THANK YOU SO MUCH.
That is the first picture of the mounted lights that I've seen, so were they mounted on the bumper bar (holes drilled in it) or on the "supporting beam", as another has mentioned.
Your info is GREATLY appreciated, from an Aussie, where this info is not available.
Thank You, Pickles.
Post #279630 5th Nov 2013 8:57am
landy andy
Mine when I brought it
Outer lights was the first thing I removed. Hate them mounted there
Andy
Post #279634 5th Nov 2013 9:03am
Pickles
Landy. I hear what you say. As I've said, they do look "odd". But without an A Bar there is little alternative other than to place them there. Were yours mounted viia drilled holes in the bar or via the alternative method via the "structural beam"?....by that I presume some part of the frontal body?...What part of the body is that, & how were yours mounted?
Information will be greatly appreciated. Pickles.
Post #279645 5th Nov 2013 9:48am
Tiger
The structural beam method is for winch bumper fitting.
No reason why you couldn't fit it there on a normal bumper unless it's not got same reinforcement
Post #279648 5th Nov 2013 10:04am
Tiger
They do look wrong on the bumper, bit Mickey Mouse
Why not get one of these?
Or fabricate something similar, to my mind although the above is better, they still don't sit quite right.
Closer and higher they need to be.
Still no drilling Thumbs Up Thumbs Up
Post #279649 5th Nov 2013 10:08am
Pickles
Tiger, I do agree with you.
Haven't seen that light mounting bar in Aus, so I don't have that option.
Regards, Pickles.
Post #279675 5th Nov 2013 11:48am
Tiger
Get one made
Post #279681 5th Nov 2013 12:10pm
landy andy
The outer ones on mine were just mounted via holes drilled in the bumper. There was no reinforcement, and I personally don't think any would be required. But they did mount them too far back so were rubbing the light surround trims.
Andy
Post #279839 5th Nov 2013 9:38pm
Honker
As Andy says 2 holes drilled through bumper. Nicely rusting now....Smile
Stu
Post #279878 5th Nov 2013 10:37pm
