Home > Puma (Tdci) > plugs and wiring
Caterham
plugs and wiring
I heard one or two mentions on here about new wiring harnesses for the engine (if I remember right around by the a/c compressor).
If you had a loose connection to say the plug on the turbo actuator how would you go about checking / remaking the plug connection?
would it be a case of resorting to a new harness?
Post #279206 3rd Nov 2013 9:59pm
bell-auto-services
The harnes is a repair harnes for the turbo actuator plug, it joins into the original engine loom after you cut back the old turbo plug.
Pete
Post #279216 3rd Nov 2013 10:19pm
Caterham
thanks Pete.
so is it a case of stripping it back circa 6" and soldering in the new?
Post #279224 3rd Nov 2013 10:29pm
bell-auto-services
Yes thats it.
Post #279226 3rd Nov 2013 10:37pm
Caterham
thank you.
need to go do some more wiggling first......
Post #279230 3rd Nov 2013 10:54pm
Caterham
if the plug to the turbo actuator does have poor connections would this tie in with the symptoms I've had in the past ie knocking like diesel knock, like fuel starvation?
to my mind the turbo gets going about 1500rpm so presumably if there is an issue with the wiring this isn't like to be evident below 1500 rpm?
Post #279293 4th Nov 2013 10:13am
