![]() | Home > Maintenance & Modifications > Lazer Lamps wiring query |
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 ![]() ![]() ![]() |
Has anyone changed or done the wiring of the Lazer Lamps on their defender differently as to what it says on the information diagram?
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8584 ![]() ![]() |
Which Lazer Lamps and what are you trying to achieve?
Brendan |
pope10001 Member Since: 15 Oct 2011 Location: Dulverton Posts: 489 ![]() ![]() ![]() |
Nope, i did it exactly as instructed and they work really well.
They are the RS4's. Did you use the standard bolts, or security ones?
Security bolts
Security bolts. You could always use a drop of locktite and silicon in addition.
Brendan |
One quick query,and that is:
Do you need the ignition cable from the relay? the reason i ask is that i haven't got mine connected and funnily enough the lights aren't working despite everything else being wired in as the diagram says! |
