![]() | Home > Td5 > Lightforce 240 Hid's fitted... |
| Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1142
Thanks to forum member SMB, I now have a pair of LF 240 Hid to fit to my 90. It has the standard LR soft protection bar. Tonight, I started to work out how they would fit. I need to cut away the grill to allow the lights to sit back flush with the A Bar, but apart from that they will fit nicely.
One problem I have is that some of the captive nuts in the top of the A Bar have come out, and I need to glue some new ones back in. Its high density foam behind the rubber outer skin. Any ideas or repair procedures? Also, is there anywhere that sells upgraded metal top A Bar brackets? the plastic ones are flimsy. Click image to enlarge Click image to enlarge 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
| Cheshire110 Member Since: 26 Jul 2013 Location: London Posts: 2791
"the plastic ones are a bit flimsy"
i always have thought that the plastic ones are flimsy intentionally to prevent damaging the grille surround if 'nudging something'.. rather bend or break a clip than push backwards into the grille panel surround IMO lights look good though! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Flimsy by design maybe, but I don't want any scumbag just ripping off my HID's, I would rather risk breaking the grill.
I just remembered that Craddocks list Mantec replacements, but I seem to recall they were not in stock a couple of years ago. Will try them again. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
| Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265
Mantec do a stainless bracket
| sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455
There were some for sale in the For Sale section a few days ago
DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
Got some Mantec brackets
Very substantial. They are bare metal, so just putting some satin black on them before fitting. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
| jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Dude,beam shots at night are good,a long, dark, straight road with a marker in the distance is better.
Yes, will post the results. 2021 Defender 110 X-Dynamic HSE D300 MHEV
| familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3502
They look like rabbit scarers!
#thebiggestlightsIcouldbuy 1995 110 300TDI 1995 90 300TDI |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18048
They remind me a bit of those daft exhausts - the size of dustbins - that the boy racers used to fit on their Corsas!
OK, I'm sorry, I'll stand in the naughty corner for an hour or so. |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Not HIDs but 240XGTs. I manufactured some brackets as seen in the picture that negates the requirement for cutting the grille. Plastic brackets still fitted, they do the job and have done for the last 5 years plus and they won't rot!
Click image to enlarge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1233
Hi Gareth,
Good to meet you the other day and thanks for the deal on the lights. Have you set them up yet? Just a word of warning, as they are 50w HID XGT's do not stand in front of them to see how bright they are or you'll have white spots for days!! Hope they are what you expected |
Yes, got them finally fitted last night. The Mantec top brackets are nice and strong, the grill was easy to cut with tin snips, and yes they are very bright indeed!
Hope to go out tonight and take some photo's. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
| All times are GMT |
