Home > Maintenance & Modifications > Rear seats into the back of a puma 90 hard top
Page 2 of 3 <123>
238kirk
United Kingdom 2003 Defender 90 Td5 SW Belize Green
The guy who makes the panels is called Pete measures, he's based nr Melton Mowbray, I bought a pair a few months ago and they are excellent quality and a doddle to fit, heres my build thread http://www.defender2.net/forum/topic16619-60.html
You can contact him here pmeasures@hotmail.co.uk
Post #277864 29th Oct 2013 8:27pm
Cheshire110
Hopefully this is helpful Smile
http://www.defender2.net/forum/topic16619-60.html Cheers, David
Post #277907 29th Oct 2013 9:52pm
Likeomg
very helpful, so basically if i don't wan't to cut the tub all i have to do is space the bottom up?
does anybody have any photos that may help with installing proper seat belts, would prefer proper over lap belts...
Post #278126 30th Oct 2013 9:35pm
Cheshire110
I've got seatbelts fitted to the rear of my 110 utility, not done by me but previous owner. Don't think they're original but they're 3 point and fit through the correct hole in the trim so obviously a very similar setup to the originals.
If you'd like ill take some pics Friday when I'm home if you think it'll help Cheers, David
Post #278133 30th Oct 2013 9:40pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
They come with an inertia reel 3 point lap over belt which has 2 locking points
Post #278140 30th Oct 2013 9:52pm
Likeomg
yeah it will help, it will give me a general idea of what i need...
chers
Post #278141 30th Oct 2013 9:52pm
mcma1
I promised you pics but got held up pulling out my seats! I can take pics of the mods tomo and will send these. I am actually cutting the tub next but only as I will be cutting out the bulkhead and side windows so while the grinder is on why not! Also if you want my mud stuff panels are for sale, adjusted to suit proper seat belts in a hard top. Thumbs Up
Post #278142 30th Oct 2013 9:53pm
Likeomg
ill maybe take you up on that, mine is currently carpeted sides which wouldn't require much modding... ill let you know
check your thread on the windows ive photoshopped it (not my best work...)
Post #278146 30th Oct 2013 9:57pm
borderterrier
you can see the seat belt configuration here
Post #278147 30th Oct 2013 10:03pm
T1G UP
mcma1 wrote:
Does anyone know who makes the conversion inserts for the rear tub?? I could never find them on eBay?
CSK..killer90 makes and fits them
Post #278148 30th Oct 2013 10:07pm
mcma1
Here some pics, the only mod needed is to the hinge point on the bracket, take the sping out and undo the bolts, re drill it and then back together, then add a hard rubber spacer, I then used a grinder to notch this out a little at a time until the seat came to sit level. The seat belt bracket attachs on to existing points. I used the load mat to position the bracket. We bonded and sealed basic fabricated plates on the underside and bolted through these.
Post #278652 1st Nov 2013 7:29pm
Likeomg
aha, i like. any chance if you have a moment, get a pic of what you did to strengthen the underside?
Post #278657 1st Nov 2013 7:40pm
Likeomg
EDIT> See further down for a better pic
cheers,
Post #279535 4th Nov 2013 10:20pm
mcma1
What do you need to know mate?
Post #279538 4th Nov 2013 10:27pm
Likeomg
better highlighted here, does anybody have the part number for this bit? guessing its the bracket for the seat belt..
Post #279541 4th Nov 2013 10:30pm
Page 2 of 3 <123>
