![]() | Home > Puma (Tdci) > Rattle when rolling free at low speeds. |
F Member Since: 09 Nov 2012 Location: Antwerp Posts: 1 ![]() ![]() ![]() |
Had the same issue,
its in fact the drum of the handbrake that isn't perfectly round. When heating up, it starts to rattle. Indeed it stops when you apply just a tiny bit of hand break |
zone30 Member Since: 07 Sep 2012 Location: Gent Posts: 669 ![]() ![]() ![]() |
It's back since this morning. Haven't heard it for a couple of days but apparently it did not sort itself.
Iow it'll need a closer look. |
Could it be brake pad rattle? It's pretty common on the back
Honker Member Since: 26 Jun 2011 Location: St Albans Posts: 353 ![]() ![]() ![]() |
As something slightly different I also had a low speed rattle, from the front, could only hear while coasting and window down. Got slightly worse when turning at low speed.
Steering damper slightly loose. |
And1145 Member Since: 04 Sep 2013 Location: Howden Posts: 30 ![]() ![]() ![]() |
I had this, found to be the handbrake. I stripped it down and found a shoe was sticking and catching the drum which is slightly out of round. Lubed all the moving bits and it has never done it since !
caribcat Member Since: 11 Jun 2009 Location: Anglesey Posts: 97 ![]() ![]() |
This has happened on all 4 company Pumas. Very common. Anyone know a quick fix? |
You can get anti rattle clips for the front and the back but fronts are ridiculously expensive for what you get.
It went away by itself...
