![]() | Home > Puma (Tdci) > Bumper with twin drls ? |
| Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 812
I can do you a custom bumper with twin DRL's... or DRL and a spot lamp etc.
All made from scratch - not badly cut into a second had bumper and then resold as per some companies. And the option of a military spec or standard. I would usually make them in 3mm (so slightly thicker than standard - but I'm not a fan of making them any thicker). Lots of options ref lights... I mainly use parts from Mobile Centre (JW Speaker) or I have just been asked to make a custom bumper and guards for a set of Rigid Industries lamps... Made to match the customers headlamp guards. Click image to enlarge Click image to enlarge Click image to enlarge Ian Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674
the 2 photos on my last post are off Nakatenenga's site they show 2 fog and 2 driving, I have 4 off Ring driving lights, re the LR loom kit it is basically an auxiliary light switch (matching the others in the dash), a relay, some wire, and a fuse, nothing special except the switch) Paul on here and others will make up looms much cheaper, however the switch itself is quite expensive, loads of alternative ways of wiring up but yes you do need a relay as the standard hb switch is a weak link.
Ian IRB I love your kit glad I'm only up the road for post warranty work DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
