Home > Puma (Tdci) > Holding its revs
Page 2 of 2 <12
bobcat
Thank you.
Post #276485 24th Oct 2013 10:49pm
myonehere
2007 Defender 90 Puma 2.4 HT Cairns Blue
blackwolf wrote:
Disconnect the high/low switch.
Be very careful if descending steep loose slopes in low 1st with idle jack disabled, since the gearing is so low there's a real risk of loss of adhesion (which is the reason for the IJ in the first place).
Do you know where exactly this switch & its plug is please?
Post #281897 13th Nov 2013 6:16pm
Norm4n
Top of transfer box?
Post #281905 13th Nov 2013 7:03pm
myonehere
thanks
Post #283502 19th Nov 2013 6:33pm
Caterham
Just trying to understand something.....
Just checked the clutch switch which appears to work fine....goes from v low resistance to v high as the clutch pedal is depressed / released......I then forgot to replace the switch and the engine revs really hang when changing gear. I presume this is right but what I can't get my head round is why the revs hanging on a gear change isn't noticeable when the switch is connected??
Confused
Post #318202 22nd Mar 2014 9:14pm
Caterham
Can anyone tell me.....
Clearly you can adjust T bite point of the clutch (adjacent bell housing) ... can you adjust the 'bite' point for the clutch switch which activates the Rev hold features?
Post #331736 18th May 2014 10:56am
Page 2 of 2 <12
